No stereo bus from a 5.1 track?
Hey all. I've run into a roadblock in trying to get increasing amounts of control. I've got all my FX (BG, Foley, hard FX, PFX) on a 5.1 bus before hitting the master output. I have a scene where I'd like all the backgrounds to be gradually sent to reverb, so to avoid having to deal with this track by track, I created another 5.1 bus for just BG, which is then output to the main FX bus. But I'm unable to send the BG bus to a stereo reverb. Only mono and 5.1 options seem to be available as sends on 5.1 tracks, and I don't have any 5.1 reverbs. Is this normal, or am I missing something?
Re: No stereo bus from a 5.1 track?
This is normal.
Workaround (of sorts but not pretty) Create a 5.1 Aux for your reverb and insert a Downmixer as the first plugin. You'll then be able to have your stereo Reverbs. This now stereo aux can be routed out to a 5.1 bus. As I said, workaround, not pretty but will get you something hopefully. C |
Beautiful, that works! I'm still trying to get my head around why a stereo bus can't be derived from a 5.1 channel, but I'm sure there's some inner logic to it that's beyond me. Thanks much.
Custom i9-12900K, 64GB RAM, W10 Pro, PT Ultimate 2024.03, HD Native, OMNI, Digi 192, UAD-2 Octo; Mac Pro 12-core 3.46, 64GB RAM, Mojave, Logic Pro 10.5.1, Apogee Rosetta 800, UAD-2 Quad, MOTU 2408 Mk II: MBP mid-2012, 16GB RAM, Mojave, MOTU 8-Pre-ES, Pro Tools 2021.7 |
Yes, all the 5.1 busses have sub-paths, but only 5.1 and mono sub-paths show as send options.
I believe the inner logic is "no, that's not what it is designed to do" hopefully Avid will take a good hard look at the panner in light of multichannel workflows and delivery formats and come up with a new built in panner that is capable of scaling and routing to greater than 7.1 paths without third party panner plugins or complex routing workarounds.
Glad the crazy routing helps you out for now though. Craig, subpaths in this sense will only allow you to route to part of the 5.1, it doesn't give your the functionality to send stereo tracks to a stereo subpath of a 5.1 bus. It SHOULD but it doesn't. C |
Any track that is above stereo will only output what that track is and or mono.
LCR outputs LCR and or mono Quad outputs Quad and or mono 5.0 outputs 5.0 and or mono 5.1 outputs 5.1 and or mono mono and stereo tracks will output anything. |
Bussing Efx to Aux Track and then bounce project to a Stereo Track | arb232 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 12 | 01-06-2012 06:17 AM |
On a stereo audio track, the left track is completely dead | ckwhy2008 | Pro Tools M-Powered (Mac) | 1 | 04-09-2011 04:16 AM |
Conver stereo track to SINGLE mono track | markolone | Pro Tools M-Powered (Win) | 1 | 07-30-2010 07:09 PM |
Stereo track vs. Mono track vs. Stereo Interleaved track >>>>>>>>>>> | peter parker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 18 | 06-26-2002 03:21 PM |
can you not copy automation data from a mono track to a stereo track? | Felix | Tips & Tricks | 5 | 04-09-2002 06:32 PM |
