sondblaster audigy crashes?
hi to everybody this is stefano from italy.i've just bought an audigy card. my system is amd 2000 512ddram 40ghd. i've installed ptf on my pc but when i try to start the program my pc crashes. could you help me?
Re: sondblaster audigy crashes?
Do a search here for Audigy drivers. Sounds like you may need to download new ones for your soundcard.
Faccia una ricerca qui per i driver di Audigy. I suoni come voi possono avere bisogno di di trasferire i nuovi dal sistema centrale verso i satelliti per il vostro soundcard. |
thank you stone (also for Your italian style).i've this powerful pc but i can't start try to do music.you can image i'm quite afraid. could'you please repost the link because i can't see it.
Hi!
I use "special" drivers for my SB live 5.1 player, but I think they don´t work with Audigy cards. The drivers let me work with PTFree, without them I was not able to use PTFree. The original Creative drivers seem to have a bad performance. But if you´re sure the soundcard makes problems try this: http://www.kxproject.spb.ru/ But READ THE INSTRUCTIONS!!! You have to download the drivers AND two modified .dll files (MFC and MSVCRT libraries (Debug versions)) from this site. Without the .dll´s it doesn´t work. I nerver tried them but i´ve heard many good things of it. Use them at your own risk! If the drivers do not give you that satisfaction you want, try my drivers, maybe they work, I REALLY DON`T KNOW -> http://come.to/sblive and click on "AUDIO PRODUCTION STUDIO".(Get rid of the "Gator" installation request by pressing Alt+F4!!!)
My ears! My ears! clausiii ----------------- MacBook Pro i7 Quad 2.6GHz 16GB RAM ProTools 2020.11 Avid S1 Avid Dock Avid Control Digidesign Command|8 macOS Catalina MOTU 4pre MOTU Track16 Axiom Pro 25 LinnStrument 128 Roli Seaboard Block tons of stomp boxes tube amps guitars noise |
thanks clausiii. i went to see what you suggested.it's my first pc and i'm not so confident with all the trick like downloading strange file.i would prefere an official solution.maybe i did something wrong installing ptf like setting the pc.i've just enabled motherboard soundcard and installed audigy player.could i've forgotten some setting or anything else??
thanks again to everyone is helping me you're great!!! |
I would try this. Uninstall PTFree and delete afterwards all Digidesign folders (some will not be deleted through uninstall). Search your harddisk with Start->Find for "Digidesign"
Delete/Uninstall the Audigy drivers and restart. Go to your BIOS (during booting press Del or F8, it depends on your PC) and disable your onboard soundcard. It could be possible that your onboard SC makes trouble (same interrupt shared with the Audigy??). Restart Install the Audigy Restart Install PTFree Reastart Good luck clausiii [img]images/icons/wink.gif[/img]
audigy 2 and pt free? | miro mackie | Digidesign Hardware & Software | 0 | 02-25-2003 06:19 AM |
16 bit vs 24 bit (SB Audigy vs digi001) | dwny | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 06-12-2002 03:03 PM |
PROBLEMS WITH VIA MOTHERBOARD and SONDBLASTER LIVE PLATINUM | JINGLES STUDIO COLOMBIA | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 05-30-2002 12:52 AM |
PTLE with SB Audigy? | musicm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-09-2002 08:26 AM |
SB Audigy Platinum fix | bassplayer | Digidesign Hardware & Software | 2 | 12-03-2001 06:23 PM |
