Firewire cable?
If I removed the ground pin from the firewire cable would pro tools still communicate with the digi002? Im getting a ground loop problem and want to know would this help. I was thinking it wouldnt matter as the digi002 is ground by the mains plug, and the PC by its plug.
Re: Firewire cable?
The problem is not the firewire cable. There are a thousand people running 002 and computer with both grounded and no hum. And I would not expect it to work anyway. Start with some general troubleshooting. Is the 002 plugged into the same outlet(or strip) as the computer?(it should be). Are you running balanced cables to the speakers? Have you tried using an AC ground lifter on each speaker? Unplug everything NOT mentioned above so you can track down without having lots of extra stuff to deal with.
If AC ground lifts on the speakers helps, can they get plugged into the same Plug as everything else? If not, with balanced cables, you can open the plug at either end and disconnect the ground/shield connection(at one end only). Use the AC ground lifter to diagnose, but its not the correct solution. Let us know what you find.
Re: Firewire cable?
The outputs from the digi with ear phones are crystal clear, the digi connected to the mixer is fine too, when the firewire cable is connected (digi on or off) the noise on the mixer is there again.
Re: Firewire cable?
I tried lift the ground and it didnt make any difference anywhere on the chain. I dont think they are balanced cabes, most are RCAs. The digi and PC are plugged into the same strip. I unplugged all the other crap and its still there. The same sound is there from the other PCs to the mixer but its stronger on the channels the digi goes into.
Re: Firewire cable?
Try a different firewire controller (not a different port), yours may be giving up.
Re: Firewire cable?
Tried three different ones. Thats why in the other post I was asking about the certified ones.
Re: Firewire cable?
What are the possibilities of a damaged FW cable? I would try swapping that with a known working one.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
Re: Firewire cable?
This may be part of the problem:
"I dont think they are balanced cabels, most are RCAs." Cheers,
Re: Firewire cable?
jono!! did you ever find a solution?? i am having the exact same problem! contact me
andrew.mcdonnell(at)gmail.com |
Re: Firewire cable?
I would unplug ALL cables from the 002 (except power and firewire) and see if you get the hum. If no hum, then start plugging cables in one by one to find if there's one cable or combination causing the hum.
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
Need A Firewire Cable. | philip888 | General Discussion | 2 | 04-18-2013 11:00 AM |
switching from USB cable to Firewire cable | moonwalker2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 11-02-2009 08:21 AM |
Firewire cable replacement??? | digifriend | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 14 | 10-18-2009 02:48 AM |
Bad Firewire Cable... | Dogcode | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 08-11-2006 06:20 PM |
Firewire cable lengths | TimP63 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 02-18-2005 06:54 AM |
