what is the best way to submix toms?
i have 4 tracks of rack toms that i want to mix to a single new stereo audio track so i can delete the original 4. what is the best way to do this? should i just assign the 4 tom tracks outputs to a new stereo audio tracks inputs and arm the track and record it or is it better to use busses on the tom tracks into a new stereo track?
Re: what is the best way to submix toms?
Use a bus: create a new stereo audio track, make a stereo bus it's input and use that same bus as output for your tom tracks. Once you have the right levels, you can record.
If you want to use effects on the bounce, you can send it to an Aux input first. |
if you are using PT 6+ because you can just turn the voices off on the unused tracks that way if u decide to change them later u can turn the voices back on and fix what u want then re bounce them, but if u submix them and then delete them ur screwed if u want to make a change
www.klarityrecordingstudios.com |
good point. |
...and for my next stupid question; How do you turn off the voices?
ASUS A7N8X-E Deluxe MD Athlon XP3200+2.20GHZ Corsair XMS PC3200 400MHZ 1GB WD EIDE 10GB WD EIDE 250GB XP Pro SP1 ProTools LE 6.4 |
Page 98 of the PT reference guide talks about how to set the voices. Click on the voice selector ("dyn" right underneath the faders in the mix window) and turn them off from there. For submixing, I just make the tracks inactive after I'm done bouncing them. I leave all the plug-ins on them and just make them active if I need to mix them again.
https://www.thirdeyerecording.com/ |
Are toms recorded 1 track to 1 piece, or all toms on 1 track? | rockguitarist1255 | Pro Tools 10 | 8 | 02-17-2012 09:27 AM |
Bottom Mic for Toms | irecordyou | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-12-2007 02:32 AM |
Shure 57 on toms? Or what would you use for <$150? | GothicV | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 16 | 07-17-2005 09:44 AM |
OT: sm58s on toms | Brad Ferguson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 07-08-2003 08:51 AM |
best mic for micing toms?? | jacko32 | Tips & Tricks | 28 | 11-17-2002 09:06 PM |
