Old 02-18-2014, 02:14 PM
Mubeau Mubeau is offline
Default best way to copy and allocate clips on new harddisks
Dear all,
During sound design it still happens that some files are not allocated to
the session´s Harddsik - I don't know why (disk allocation on all track is set to session´s Harddsik). Yes I have "automatically copy files on import" activated.
Sure when I´m done i would do "save copy in", but whats the best way if there are only some clips on the "wrong" HDs?
- I also COULD consolidate these files.
But what if there are many clips on the "wrong" hD (not the session HD where I want them to be).
I hope you understand what I mean an perhaps there is help for this nasty "bug"….
Thanks!,
Mubeau
Old 02-18-2014, 04:14 PM
C C is offline
Default Re: best way to copy and allocate clips on new harddisks
Use the Project Browser window.
Open up the Audio Files "folder" (it's a virtual directory of all the audio files in the session) and sort by Path.
You should be able to select files which are on incorrect volumes and the use Copy and Relink to copy them into a folder of your choice and relink them in the session.
C
Ceri Thomas
Personal Site
Mix Tech/Assistant Sound Editor
Old 02-19-2014, 11:26 AM
yes thanks a lot. thats it!!!
any idea about this import "bug" / strange behaviour that PT does not ALWAYS import new audio file although you had chosen to do so?
thanks!
mubeau
Old 02-19-2014, 12:00 PM
Craig F Craig F is offline
if the clips are on other HDs, you can change them to Transfer drives, open the session and PT will copy into the session folder
Thank you,
Craig
Old 02-19-2014, 01:01 PM
C C is offline
Try instead of Copy files using the Force to Target session format on import. never had it fail that way.
Ceri Thomas
Personal Site
Old 02-20-2014, 11:09 AM
FajitaTone FajitaTone is offline
This is what I do.
Ray Trujillo
Freelance Audio Engineer
HTML code is On
MIDI clips/regions copy/loops madmarkdj Pro Tools 11 5 09-08-2021 10:33 PM
Exporting Clips as WAVs, clips dont highlight in list gigantorbuzz Pro Tools 10 6 08-05-2013 01:07 PM
Copy multiple clips? georgepeter macOS 6 03-07-2012 10:02 AM
Drag and copy clips superproducer Pro Tools TDM Systems (Win) 5 01-08-2006 04:56 PM
how to set up 2 Harddisks and 2 CD-Roms tom_h 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-07-2003 01:33 PM
