TL-Space stock IRs won't load... any ideas?
I just downloaded and installed TL-Space (TDM). The plugin seems to be installed properly and works perfectly with my other WAV type IRs, but I can't seem to get the stock ".tls" IR packages to install. When I select to install one, the box comes up confirming the package, but after I hit "install" I get this error:
"One or more files were not written. Please check log for errors." All downloaded all of the separate packages direct from Avid. I get the same error with every one I try to install so I highly doubt the download got mucked up for everyone. Any idea what the deal is? I'm running Protools 10.3.2 HD on OSX 10.6.8. Thanks for any help with this! John |
Re: TL-Space stock IRs won't load... any ideas?
Maybe this helps, although it refers to Native :
When using the "Install TL Space IR Package" function and pointing to a .tls file, the following error occurs: "One or more files were not written. Please check log for errors". Why? In one case this was due to the following file path not being written by the TL Space Native installer: Mac HD>Library>Application Support>Trillium Lane>TL Space>Impulse Responses This was resolved by closing Pro Tools and manually creating the missing folders. When Pro Tools was relaunched, the IR packages could be installed successfully with no error message.
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 Last edited by joachim; 03-10-2013 at 07:10 AM. Reason: forgot what |
That did the trick! Thank you!!!
I had actually tried to create the folder path manually before I posted my question... the key in your solution was to shut down Protools. Again, thanks so much! John |
TL Space Load IR | justus1900 | General Discussion | 0 | 07-31-2012 07:41 AM |
TL Space Impulse Responses won't load | Bart Budwig | Windows | 4 | 02-09-2011 03:13 PM |
Can't load TL Space IR Library! | denka | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 01-17-2007 11:19 AM |
help!!!! tl space won't load | bluetuesday | Pro Tools TDM Systems (Mac) | 3 | 04-19-2006 07:14 PM |
TL space load sloooowww | roundbadge | General Discussion | 0 | 11-02-2005 12:59 AM |
