Video to external monitor recommendations
In the process of planning out an upgrade from PT10 on a cheese grater to a Mac Mini M1.
The M1 only supports 2 monitors, and I am using them for desktops, and I would prefer full screen output to my projector over a 3rd desktop anyway. Can I use an AJA thunderbolt for HDMI output from Pro Tools or what can I use? Thanks! |
Re: Video to external monitor recommendations
Then use one of these options. https://www.sonnetstore.com/collecti...ayport-adapter https://www.sonnetstore.com/collecti...l-hdmi-adapter Double check on the monitors because all I remember was that it said over Thunderbolt.
Mac Pro 5,1. 3.46 12 core, 128 gigs ram, 580 GPU flashed Apple EMI, 3 monitors PT Ult 2023.6, OSX 10.14.6, 3 card PCI-e expansion with 3.2 USB Sonnet card. OCTO 8 card, Apollo 8 Quad, UAD quad satellite FW. Almost every plugin |
Hmmm, I read it 2 total. I am using one from the built in HDMI out and then a Thunderbolt to HDMI. I have not tried a 3rd to even challenge that assumption. Can you get fullscreen video on one of those? I always disliked having the Window frame top bar above the video. But I can crop/zoom the projector to hide it. edit: https://www.macrumors.com/2020/11/24...rnal-displays/ So I see it possible... thanks something to consider in addition to a dedicated video out. Last edited by Qwertypo; 10-21-2023 at 05:04 PM. Reason: additional details |
https://www.sonnetstore.com/collecti...k-display-dock Just use one HDMI for your projector. However, I think the border edge is built into the OS if you are using a display port. If you have an external box and set protools to external video (whatever it is in the menu) you won't get the border.
Mac Pro 5,1. 3.46 12 core, 128 gigs ram, 580 GPU flashed Apple EMI, 3 monitors PT Ult 2023.6, OSX 10.14.6, 3 card PCI-e expansion with 3.2 USB Sonnet card. OCTO 8 card, Apollo 8 Quad, UAD quad satellite FW. Almost every plugin Last edited by audiolex1; 10-21-2023 at 06:07 PM. |
If you get a displaylink adapter and use that for one of your monitors, you can run three. I did this with my M1 Mac Mini and it worked fine. You need to have the displaylink driver running all the time.
But they make a USB type c thunderbolt version now. https://www.sonnettech.com/product/t...t-adapter.html
I run 2 x 27" monitors via TB, One 50" LCD over HDMI and one 15" for Meter Plug ins via USB-C on my M1.
that would help.
Is there a similar device that is better? Is there a specific model of the AJA I should look for? If not I will try the thunderbolt to dual HDMI, and likely get a thunderbolt expansion box from OWC Sent from my iPad using Tapatalk Last edited by Qwertypo; 10-22-2023 at 12:28 PM. Reason: added some details |
https://www.youtube.com/watch?v=LucX...lHcsdr&index=8 I don't know much about AJA. However, you might consider this expansion. https://www.sonnetstore.com/collecti...o-express-se3e OWC doesn't have many PCIe options. I saw only 1 with 1 PCIe slots where the Sonnet is 3 PCIe slots. I know Blackmagic has PCIe cards for external video as well. Relatively inexpensive from what I remember. Might want to search youtube for some users experience.
Outputting Video To External Video Monitor | chadjhughes | Pro Tools 2019 | 3 | 01-05-2020 02:58 PM |
Recommendations for QT external monitor...? | Jon_Atkinson | Post - Surround - Video | 3 | 03-26-2012 02:15 AM |
Third monitor video card recommendations? | xxicjoy | Pro Tools TDM Systems (Mac) | 1 | 02-04-2010 11:58 AM |
6.9.1/video to external monitor | soundproof | Pro Tools TDM Systems (Win) | 3 | 09-27-2006 01:18 PM |
Video Monitor Recommendations? | meshtheflesh | Tips & Tricks | 4 | 06-24-2000 10:07 PM |
