Old 10-14-2023, 05:08 AM
PhiltheGreek1 PhiltheGreek1 is offline
Default Multichannel vs multimono
Just checking something; In an atmos session, with DA renderer, when I have a 7.1.2 send to a 3D plugin such as Symphony, or Slapper - if the plug is multimono then panning the send goes as expected - but if multichannel then the pan seems to make no difference..
Is that as it should be?
Thanks
P.
Old 10-14-2023, 06:07 AM
LDS LDS is offline
Default Re: Multichannel vs multimono
It seems to be working fine here. What are you expecting to hear?
A multichannel instance of Symphony functions similar to a real acoustic space. Throw a ball into the corner, and the resulting reverb will come from all directions. Panning the send changes the early reflections of where the ball lands, rather than the acoustic space itself.
Multimono will just stick 10 mono instances of Symphony across your 7.1.2 track. Panning chooses which of the 10 mono instances that you are sending audio to. An alternative approach would be to just use a mono instance on a mono aux, set the aux to object and assign it to the same object number as your source sound. The mono reverb will then follow your source sound panning.
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command.
Old 10-14-2023, 07:32 AM
Ahh thanks ok makes sense.
I was panning a VO in a large long corridor type space with hardly any early early reflections. The multi mono sounded not great, but I could hear the movements.
HTML code is On
Multimono plugin preset gugu AAX Plug-ins 3 03-18-2020 03:54 AM
EQII multichannel and multimono? usd Pro Tools TDM Systems (Mac) 7 10-27-2008 10:48 AM
Multichannel and multimono when and why ? jeam25 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-19-2008 10:25 AM
Learn this lesson about Multimono Plugins deanguidry 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-28-2008 01:19 PM
Waves L1 limiter multimono question poldo Pro Tools TDM Systems (Mac) 0 01-24-2003 12:24 AM
