Old 03-09-2023, 07:47 AM
gives's Avatar
gives gives is offline
Default Re: AAF import stereo issue
Originally Posted by trevora View Post
The multicam issue is where the multicams are built incorrectly in premiere (it's easy to do wrong). Everything sounds fine in the edit but on export to AAF (where PP flattens to the constituent files) you may get silence, or the wrong tracks (eg cam mic not lavs).
Easiest workaround (other than building multicams correctly) seems to be to export an OMF (which seems to bounce the multicam bus output, rather than consolidate its sources.
It's more a PP multicam problem, rather than an AAF problem (as you get the same problem in the PP timeline if you flatten it*).
The dual mono issue seems to be an AAF problem, TBD if it's prem export or PT import at fault. (Although OP did say that importing offending AAF back into PP was stereo.)
*Although you say your editor fixed it by flattening? So maybe this is a different PP bug.
Probably and I hear ya! We were on a fast track to get this done in hours because of a month delay. I did not have this issue before, but not really an expert with the Premier software, but the OMF always works. Thanks and I will pass what you said on. The job is out the door, so all good!
G
Composer/Sound Designer/Protools 2024.3 Ultimate, MTRXII-TB3, DADMAN MOM, Cisco SG350-10MP EthernetHUB, KLANG:quelle 4 Channel Dante™Headphone Amp, DVS,MADI, Mac Studio Ultra,128 RAM/4TB SSD, Ventura 13.6.6, DP 11.3.1, Logic Pro X 10.8.1 DOLBY ATMOS Facility/MPSE Motion Picture Sound Editors Avid Certified Professional ProTools/Dolby ATMOS
Old 03-10-2023, 04:44 AM
Schottlandru Schottlandru is offline
Horrible to hear about errors that are "introduced"...
Regarding OMF - wow, feels a bit vintage - that doesn't pass along all metadata, or does it now? Timecode, scene/take name, clip name from the actual WAV file...
I thought I remembered AAF with media files folder in broadcast WAV worked best for this... but maybe this is me mixing up Resolve tests too.
Old 11-23-2023, 11:21 PM
trevora trevora is offline
Reread this, as I'm back troubleshooting AAF.
I exported Prem Pro AAF and imported back into PP and anything other than mono clips does indeed double up the first track - so LL instead of LR.
Avid MC AAF -> PP seemed OK with 2xmono/stereo sources
HTML code is On
Import Stereo Files Panacci Post - Surround - Video 1 02-13-2017 07:48 AM
OMF Stereo import Lynx1961 Pro Tools 12 6 09-21-2015 06:10 AM
omf aaf import to stereo??? Extreme Mixing Post - Surround - Video 2 12-20-2012 12:09 AM
can't import stereo files? msg6794 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 12-27-2007 10:05 AM
Import/converting wav stereo files Oli P Pro Tools TDM Systems (Mac) 6 01-02-2001 07:11 PM
