Old 08-20-2009, 06:19 PM
modemdavid modemdavid is offline
Default STRIKE! Corrupt VISUAL display/ Fix?
Just installed STRIKE v 1.0.0.2548 /
The VISUAL display of this plug in appears seriously corrupted
(mostly yellow/ text on page blurs into illegible schmear trying
to go through style settings, etc).
Program RUNS, audio good - all my other plugins appear
perfect visually and system is otherwise running fine.
Tried to reinstall software, same result.....perplexed.
Any suggestions? Thanks.....
Old 08-20-2009, 06:23 PM
ankely ankely is offline
Cool Re: STRIKE! Corrupt VISUAL display/ Fix?
You apparently need a newer version:
http://www.digidesign.com/index.cfm?...11&itemid=4952
Pro Tools 10.3.9, MBP 2.4GHz Intel Core 2 Duo OS 10.6.8 4GB/Ram, 7200RPM 750GB Internal HD, Focusrite Saffire Pro 40, Digidesign Mbox 2.
It is what it is...
ScrewMakerMusic
Old 08-20-2009, 09:59 PM
Default Re: STRIKE! Corrupt VISUAL display/ Fix?
No....don't think that's it / just purchased this direct from
Digidesign this week // running Pro Tools 8.0 on a new
iBook.
Again, all other plugins display/work fine.
'Strike' will play, but its almost unusable because of the
display problems /// also seems to be crashing system...
help!
Old 08-20-2009, 10:51 PM
oulablank oulablank is offline
go to www.airusersblog.com and click the word "yellow" on the right side of page under " key words "
Old 08-21-2009, 01:32 AM
lclebsch lclebsch is offline
Thanks for the link to the AIR blog site. Very cool.
I'm having the same problem though, and the graphic anomaly was not fixed by downloading the most recent update. It has my Sweetwater tech perplexed also. Sometimes it works fine, other times it acts "buggy." But it's practically unusable because of the illegibility of the text in the menu. I'm going to try to delete my DAE prefs and re-start and see if that fixes it...
Anybody had this problem and gotten it fixed yet?
Old 08-21-2009, 06:51 AM
For the record, using VERSION 8.0 Strike
Old 08-21-2009, 06:56 AM
Correction ....checked box which shows
STRIKE v 7.4 Rev B. So, is there an update/potential fix?
Old 08-21-2009, 08:20 AM
spkguitar's Avatar
When you click the "Strike" name on the plugin interface, the version should read "Version 1.0.2 Build 7527". (at least, mine does)
As mentioned, the updaters can be downloaded from the Strike Product Page
Old 08-24-2009, 04:02 PM
I've updated. Strike.dpm is 1.0.1.2816. That's the most current one, correct? But I'm still having the problems, and it's not just the visual anomoly. The whole program is acting buggy. Sweetcare support doesn't seem to have any suggestions for me. Anybody know what the deal on this???? It's KILLIN' me to not be able to work!
Old 08-25-2009, 07:30 AM
spkguitar's Avatar
No.
Strike data7.big corrupt Henks Windows 1 06-15-2011 01:10 PM
Display stuttering, timeline shaking, visual delay nossnevs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-24-2010 02:18 PM
MacPro Dual Display Bugs & Error -600 Corrupt File CS3 Bug Nathan W. Post - Surround - Video 3 08-14-2009 11:58 AM
Visual display of the sound file Mac Shack 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-04-2005 10:41 PM
visual display of audio information Percustard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 11-28-2004 09:36 PM
