Old 03-21-2009, 03:40 PM
protonneutron protonneutron is offline
Default Cant use Score Editor????
Trying to use Score editor with a Guitar track....Using Eleven...it's a audio track. Score editor will not open and its greyed out...Right clicking on track will not show option for Score editor......Its work ed before...used it with Grand mini and other projects, however this is the first time using it after the update in Feb.
Macbook Pro 2.33 ghz 4gigsram, Protools 8.0.cs2 or whatever the most current update is, Digi003 factory, Glyph 350...
I watched Lyndas tutorals and followed to the tee but Score editor will not open
Old 03-21-2009, 05:30 PM
Thedspeth Thedspeth is offline
Default Re: Cant use Score Editor????
I haven't had a chance to mess around with score editor but I don't see how you could possibly used score editor with an audio track.
It works with Grand mini because that's an instrument/midi track and the midi notes are converted to a score.
Or I could be speaking about something I have no idea about!
Pro Tools 9
Symphony I/O
Mac Pro 8 core
Gear: UA 6176, UA 2-1176, Daking IV, Presonus ADL-600, 2 GAP PRE73
Other Software: Ableton 8, Reason 4, Sibelius 6
Plugs: Mercury Bundle, Full UA
Old 03-21-2009, 06:03 PM
David Penick David Penick is offline
I'm also pretty sure the score editor only works with MIDI info. There's no way for it to convert audio to the score.
Mac Mini M1 2020
Mac Sonoma
Pro Tools2024
Pro Tools Carbon
Old 03-21-2009, 06:05 PM
Thanks for the reply, I was scared of that....again thanks for the reply. I wonder if I could bus the audio to a midi track, and then use Score edit...
Old 03-22-2009, 12:04 AM
flommer flommer is offline
Midi is only instructions (play this note, at this time, for this long... etc) It is not audio. It is only useful for making some other device produce audio
It is not as simple as bussing, but there are 2 things I know of that might work..
You need some kind of program that will analyze the audio and produce MIDI data from that..
Celemony Melodyne does this in the full version ($500 I think). I have no idea how well it works, but they supposedly have technology that can figure out the individual notes in guitar chords..
Steve Massey makes great plugins for ProTools and if you buy one of them, you get his DTM software for free. It is designed to work with drums, so for guitar it might not be of much use, other than timing info.. Not sure..
http://www.masseyplugins.com/?page=dtm
Once you have a MIDI track the score editor should work...
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R
The Score Editor in MP 8 RichrdC Pro Tools M-Powered (Win) 0 07-12-2010 01:20 PM
Score Editor in PT8 DavAshMusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-27-2010 01:15 PM
Score Editor ? drummer9 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-07-2010 09:44 AM
Score Editor Bug? Maars 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-21-2009 03:43 PM
Score editor f0h Pro Tools M-Powered (Mac) 1 08-04-2009 05:35 PM
