Pro Tools & Waves...
Hey Everybody...... How's it going?
How do you Guy's save you own Waves presets in Pro Tools? Also.... Where do you save them for backup? There's like three or four ways to do it. Man... it can be confusing. Heres where I'm at.... and not sure which is best. According to Waves.... they say to use the Save button on the right side of the plugin, next to their Load button and then click ...."save to new file" which saves it as the plugin name, for instance, in TrueVerb, when you click "save to new file" it would be.......TrueVerb setups.xps .... with this ."xps" extension. Then you give it your name, choose your destination & click save. Then click ..."Load", "open preset file" and navigate to the file you just created... "TrueVerb setups.xps", highlight it and click Choose" Now when you click the load button, above the factory presets, you'll see "TrueVerb setups" underlined with the preset you just created there beneath it. Or.... you can create another preset after after your first one and then again click the save button next to the load button an this time choose...... "Save to TrueVerb setups.xps As...." Then give this preset a new name and click "OK" Then if you if you click..... Load, "open preset file" and navigate to the file you just created... "TrueVerb setups.xps" ..... highlight it and click Choose" The two presets you just created are listed above the factory presets as "TrueVerb setups" with the two presets you just created. Also..At any time you can then save these presets to the "User Preset Menu" by cliking the Save button next to the Load button .... This time choosing.... "Put Into Preset Menu As"... give it the same name as it already is an click "OK" Now when you click the "Load" button, you'll have those same presets beneath the Factory Presets, listed under "User Presets." Now here's the other way....... On the upper left hand side of the plugin click the arrows next to factory default and choose... "Save Settings As".... and save it to a desired location. Now when you click "Factory default" on the upper left side you get these saved presets in the "Plugin Librarian" as, this time a..... ".tfx" file. Which is the right way or the best way to save these Waves presets? This can make you crazy. Well it's making me nuts. Whew....Thanks |
Re: Pro Tools & Waves...
Wow.... Nobody here is using Waves......
What are you all using for good quality plugins? Thanks. |
I usually save mine to the menu so it appears without having to search for it.
Larry PT 2021; MacBookPro M1; 16GB; Spectrasonics; Native Instruments, Toontrack, Waves...too many plugins. |
That's the way I save mine, too. To me, the easiest way is the best way.
Mac Mini M1 2020 Mac Sonoma Pro Tools2024 Pro Tools Carbon |
me too
Shorty: Table Syrup Records Mac Pro 5,1 3.33 GHz Hex, 32GB EFI Flashed - 5 GT/s Modded 7950, Dual Apple 23" OSX Sierra Pro Tools HD 11.2.2 Waves IOS, IOX, STG2412 Extreme Server (x2) Logic Pro X, DSP Quattro, Final Cut Pro X Waves Mercury+SSL+AbbeyRoads Trident S65 with embedded US-2400 Live: 2012 Mac Mini, Dual SSD, i7 2.4, 16GB Win 10, OSX Sierra LV1, MRSG Hardware from above (same gear) Dual Dell P2418HT Touch Screens Waves Icon X (x2), M, with Screens Custom enclosure |
Thanks for the replies!
When you save your presets in the preset menu using.... " Put Into Preset Menu As..." I believe they're being saved with all of the other Waves factory presets and in the folder where all of the Waves .xps preset are there is no way to distinguish ours from the factory one's So then what do you guy's do back them up, because in the event you have to uninstall and reinstall Waves you will lose your presets? |
Time machine, dude, Time machine
I hear ya... But that's not what I'm talking about.
I'm referring to trying to save just our own presets when they get mixed in and embedded with the Waves factory presets which is what happens when you save them to the preset menu. |
You could just copy/backup the whole "Plug-In Settings" folder within the Waves folder.
Waves V8 and Pro Tools HD 8.0.4 | Nemosonic | Pro Tools TDM Systems (Mac) | 4 | 08-03-2011 10:54 PM |
Waves and Pro tools 8 | damu22 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 04-09-2010 12:10 PM |
Waves 6.0.6 and Pro Tools LE 8 - "Select Waves Plug-ins Folder" - Windows XP | toustab | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 19 | 03-14-2009 01:13 PM |
Waves 5.9.1 and Pro Tools 8.0 | JLeigh2024 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-08-2009 08:23 AM |
Waves 4.0 with Pro Tools 7.4?? | Jay Terrien | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 24 | 05-22-2008 01:23 PM |
