Why does audio stop when inserting 1st plugin?
When I insert the first instance of any plugin there is a solid .5-1 sec pause in the audio playback. I've used many other systems and not had this problem. What could be causing this. I've tried all h/w buffer size and dae playback combonations.
Mac g5 dual 2.0 ghz OSX 10.4.6 2.5 GB Ram PT HD 7.2 HD core card (plus 1 process card) |
Re: Why does audio stop when inserting 1st plugin?
The TDM buss. Heck, you used to have to stop playback to insert a plug, consider yourself lucky.
So why does it happen on this machine, but I when go to a different studio running off a G4 and it dosent happen? Could an Accel card make the difference?
For me there's usually some pause in audio when inserting a plugin, but it seems to vary from plug to plug, and also depend on whether it's RTAS or TDM.
If I want to A/B a track with and without a plugin very quickly (which is what I'm assuming you're wanting to do), I'll just insert the plug and flip it in and out using the master bypass. There's no pause or delay with that. |
no, it's not to a/b, (I'll disabel it ,Control+Apple+click, or use the master bypass) if I want to do that. I just want my first instance to not make my audio stop, it's just messes with my mojo when I'm mixing and a awkward break in the music happens you know? I most likely wouldn't care if I have not worked on systems where this didnt happen or the pause was so small that you really don't notice it. Sometimes a client will look at me with on eye closed like "what was that?" Then I tell them and it's no problem.
Chris
Splitting audio and inserting | bilug | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-08-2012 09:31 PM |
Macro for inserting a certain plugin... | GW | Artist Series | 3 | 02-03-2011 10:32 AM |
Track not in sync after inserting plugin | pingzings | Pro Tools TDM Systems (Mac) | 7 | 12-21-2009 01:02 AM |
Inserting New Audio | shultzee13 | Pro Tools M-Powered (Win) | 0 | 01-29-2008 01:41 PM |
Inserting audio into a web page | spicyitaliano | General Discussion | 13 | 12-30-2003 11:16 AM |
