G4 PT 5.0 poor Performance
I'm getting very slow performance from my PT Mix+ G4/350/DVD/256 Since a 9.0 reinstall. I have all the recomended settings (I think.
Even in a ALL MIDI session play is is very late and meters are around .5 to 1.5 frames a second! I've tryed all kinds of Extention, DAE, cache, mem settings. Any Ideas or things I should recheck?
NotoriouSS Tad PT 2023 HDX3 maxed system 7,1 Rack Mac Pro PT 5.1.3 OS9 maxed system G4 1.33 |
Re: G4 PT 5.0 poor Performance
TechSupt,
Mike CHecK! Juan. Tooooooouuuu. One one one Toooooooouuu WeeeeeeeeeiiiiiiiiiiiiiiiiAHRrrrrrrr Bonk. Is this thing on?
There are many things that can cause this... For starters try these... - extensions conflict. Use a copy of the Mac OS base set with only the Digi and OMS extensions enabled. - allocate enough RAM to both DAE and Pro Tools atleast 40 to 50 MB each for a Mix Plus system. Be sure to have enough system RAM, 192 MB or greater. - Disk cache setting in the memory control panel should be about 512k and virtual memory should be disabled. - What external SCSI devices do you have connected to the system? Removable drives that "sleep" can cause problems as well as any improperly terminated or SCSI ID's devices. Try minimizing your SCSI chain. We were running a G4/450 on the most recent "Creation" Tour dates (about 6 or 8 clinics) here in L.A. and it worked flawlessly. Let me know if this doesn't help. Jon Connolly Digidesign Product Specialist |
Poor Performance | L-Dogg | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 06-12-2006 02:21 PM |
Imac G5 poor performance | jimskiwax | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-18-2005 05:37 AM |
very poor performance | gaus | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 17 | 03-07-2004 06:27 PM |
Digi 001 - Mic Pre poor performance | Alan John | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-03-2003 01:11 PM |
Poor performance with 5.1.1 | bstaley | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 07-03-2001 09:45 AM |
