Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 02-22-2021, 10:58 AM
SFXgeek SFXgeek is offline
Default Waveform drawing after record
Our record room trashcan Mac had a meltdown and after getting it back from Apple we had to start from scratch and reinstall everything. For some reason now after we stop recording, the waveform drawing cause the cue to disappear for a second or more and then eventually shows up with the drawn waveform. Never used to do this and causes our recording engineer a heart attack every time it does this as they think they've lost the cue and slows down the session. Cleary we have not set a setting correctly but I can't find what the setting is. Any help would be appreciated. Could this be a CPU resource allocation setting or issue? Graphics card?
Old 02-22-2021, 11:02 AM
Default Re: Waveform drawing after record
Sorry, forgot to mention, running PT Ultimate the latest version on trashcan Mac running Mojave.
Old 02-22-2021, 12:27 PM
Still not enough tech info.
Sometimes it takes a little bit to finish drawing the waveform after recording stops. As long as it's all there there's nothing to worry about.
Jack
QAPLA!
Old 02-23-2021, 11:33 AM
daeron80 daeron80 is offline
Check Prefs, Processing tab, Parallel Task Optimizations at lower right. Try different settings. Just a guess.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 02-23-2021, 11:51 AM
No such thing in PT 2020.12 prefs in any tab
Jack
QAPLA!
Old 02-23-2021, 01:17 PM
It's in the Reference Guide. Page 127. Utlimate only.
David J. Finnamore
Old 02-23-2021, 01:59 PM
Thanks for the explanation.
Jack
QAPLA!
Problem drawing waveform Mack Truck Pro Tools 10 2 07-23-2012 05:41 AM
Waveform drawing Boe Larsen Pro Tools TDM Systems (Mac) 2 01-18-2012 07:53 AM
Waveform drawing fix for 7.4???? Kmajorkminor 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-01-2008 10:16 AM
Waveform Drawing Issue??? Enkonis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-17-2008 03:13 PM
Waveform Drawing Question CFS Tips & Tricks 17 10-04-2001 01:15 AM
