Old 04-05-2012, 09:21 PM
Picture Start Picture Start is offline
Default Omni mirrored outputs level drop
I'm using the option in Hardware Setup to mirror the TRS outputs from outputs 7-8. 7-8 go to a pair of meters and the TRS feed the inputs of a dual-channel analog EQ/compressor with its own meters.
With nothing plugged into the TRS outs, the level is 0dB (unity). When I connect something to the TRS outputs, the level for both the regular 7-8 outs and the TRS drop around -1dB. I sort of expected in 2012 for these to be buffered outputs. Can anybody confirm that the Omni's TRS outs do a simple mult from 7-8? Any way to avoid this? If I disconnect the 7-8 outs, I don't believe the level goes back to 0 on the EQ/compressor. Weird.
I guess that's what you get for not buying enough discrete channels.
New 00x Interface, or HD Omni price drop? M-ManLA General Discussion 3 10-28-2013 10:24 AM
Amp outputs same level as Main outputs? DonaldR Eleven Rack 0 02-07-2013 01:50 PM
Omni I/O - How to set up AES outputs? KMcK Pro Tools TDM Systems (Mac) 6 04-16-2011 02:41 PM
HD omni with a major price drop on a hd1 core onepercentfree 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 25 08-23-2010 03:16 PM
channel level mirrored in send level meter daveh 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-01-2001 01:32 AM
