Old 11-04-2005, 03:46 PM
IO Composer IO Composer is offline
Default Ya got me!
Here I thought Digi was being so generous with the deal on Revibe with my PT7 update. I had to laugh when it brought up the point that it's "accel only" in the installer. Hmm....should I spend $3K just to use a plugin that I got for $75?
Digi, you guys really should have put a notice that it was Accel only in the decription of the PT7Plus upgrade option. That's not the kind of thing that should be left in the fine print....or maybe this was intentional to sell more accell cards? Probably.
-Jamey
Jamey Scott
Dramatic Audio Post, Inc.
Burbank, CA
IMDB
Old 11-05-2005, 03:05 AM
clusterer clusterer is offline
Default Re: Ya got me!
-Jamey
...so with HD1 you won´t be able to use revibe???? jez...!!!!! is that true????
greets
G. Rasek - recording engineer - www.overdub.at - european VO talents via source-connect - PTHD
Old 11-07-2005, 12:56 AM
BW DoggyDawg BW DoggyDawg is offline
SYSTEM REQUIREMENTS
Digidesign-approved Pro Tools|HD Accel system
ReVibe is not compatible with previous-generation TDM systems
...Revibe has been always Accel-only...it´s possible to locate that info on the appropriate plug-in info page.
BW
Old 11-07-2005, 01:01 AM
SYSTEM REQUIREMENTS
BW
yep... already read it! anyhow they could make it in this case a bit clearer for costumers who´re
interessted in pt7 upgrade plus...
and u´re sure - revibe won´t run with HD1-only???
greets
