Old 10-17-2016, 07:35 AM
andrea.bonomelli andrea.bonomelli is offline
Default Euphonix MC Color: Panel not detected
Hi all.
I have a a problem getting any software detect a Euphonix MC color on one of our workstation. The panel works fine with other Desktops (Macintosh) and with any software (Media Composer, DaVinci Resolve)
OS: Windows7
Motherboard: Z9PE-D8 WS
SSD: Samsung EVO 850 256GB
2x E5-2620 v2 Intel 8Core Xeon 2.10GHz 15Mb
4x 8GB + 4GB Empty = 32GB1333MHz DDR3
GeForce GTX 680
2x GeForce TITAN Black
BMD Decklink 4K Extreme
The EuCon application installed is 3.4.1 provided directly by Avid Support. When loading it, the MC color appear in the device list. And when I try to upgrade the firmware it's says the last one is installed.
The LCD display shows normal empty square green rectangles that automatically should switch to the software-related labels in any other computer/mac.
I tried a fresh install of all the software, the os, hardware resets, both DHCP and manual configuration but no luck.
The panel is linked via Ethernet directly to the motherboard.
The right option is set in Resolve
And in Avid the right panel is selected in the preferences
RedCineX dosen't detect the panel either
Is anyone in my situation?
Thank you all for any hints
Old 10-17-2016, 08:12 AM
Southsidemusic's Avatar
Default Re: Euphonix MC Color: Panel not detected
Hi and Welcome to the Community
Just making sure, did you check the peripherals and made sure eucon is ON ?
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 10-19-2016, 01:49 AM
Hi southsidemusic.
Yes otherwise I won't be able to get the panel in the EUControl device list....
Old 10-19-2016, 07:02 PM
EddieJones's Avatar
There was a bug fixed in v3.5 that may help with not being able to connect on Windows systems.
Old 10-21-2016, 03:46 AM
Thanks updating to 3.5 fixed the problem.
3weeks of headache sorted!
Mac: Euphonix Preferences panel drops non-eucon apps avezeau Artist Series 8 11-28-2011 07:07 PM
Track Color / Region Color? suitelounge 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-23-2009 10:11 AM
LE v7.4-Color Palette & Track Color Coding Vbhalla Tips & Tricks 4 01-02-2008 04:13 PM
Control+Option+Command/ Color palate track color KingFish 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-28-2007 08:54 PM
High color or true color?? phdumas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-22-2002 12:43 AM
