Old 04-21-2021, 09:54 PM
freakhouse freakhouse is offline
Default Plugin authorization issues
Recently I did a fresh install of Pro Tools Ultimate (latest version). Since then if a session has been open for a while and left unattended I will get popups saying various plugins are not authorized. These are plugins by different manufacturers.
ilok manager is running the latest version. All my ilok plugins are on a physical ilok, no cloud session is open. I'm not 100% certain that all the plugins that are giving errors use ilok.
Example screenshot attached
File Type: png Screen Shot 2021-04-21 at 10.13.22 AM.png (45.4 KB, 0 views)
Old 04-22-2021, 04:23 AM
Default Re: Plugin authorization issues
Liquidsonics plugins use iLok. Is your iLok plugged into a hub or direct? Try going direct into the computer. USB2 or USB3 ports on computer? iLoks sometime have issues with USB3 ports. What exact Mac do you have?
Old 04-22-2021, 12:34 PM
I'm on a Mac Pro (late 2013) - Catalina 10.15.7
I do have the iLok on a hub. I'll move it directly to the computer and see if that helps. thanks for your suggestion.
Old 04-22-2021, 02:58 PM
Moved the iLok. It's now giving errors while I'm working, not just when idle. I'm attaching the latest one.
File Type: png Screen Shot 2021-04-22 at 2.43.27 PM.png (24.0 KB, 0 views)
Old 04-22-2021, 11:09 PM
I read that you recently did a fresh install of Protools. Did you update to Protools 2021.3 or 2021.3.1? Were you on this version before the fresh install? Did you update to a newer OS (Big Sur)?
The reason for my questions is that some plugins have not been updated and certified for Big Sur and some plugins have not been updated and certified for Protools 2021.3 and 2021.3.1. You might need to check with the plugin manufacturer to see if they have an updated version that is certified for the OS and Protools versions you are running.
Obsidian Dragon
Mac Studio M1Max - 64GB
Old 04-22-2021, 11:28 PM
I’m on Catalina. Latest version of pro tools - .1 fixed update that just came out. I’ve got a ticket in with iLok now as well.
It was a fresh install of Catalina on a new drive. My old ssd failed. I installed the first 2021 version I believe l, whatever was current at the time. This was about a month ago.
Old 04-23-2021, 12:16 AM
JFreak JFreak is online now
Originally Posted by freakhouse View Post
My old ssd failed.
Are you sure all of your licenses are actually on the iLok license key? Perhaps some of the licenses where machine authorizations (stored on failed SSD) and therefore lost?
Old 04-23-2021, 06:24 PM
You might need to reinstall these plugins and reauthorize them according to the manufacturers process. As mentioned above, some plugins are machine authorized on the SSD. Your best approach is to contact the manufacturer's support department and indicate your situation. They should be able to resolve the authorization problem with you.
Obsidian Dragon
Old 04-24-2021, 04:27 AM
To add to this is something I saw the other day. That is some plugins use Pace/iLok s/w to authorize the plugin but don't actually use the iLok (whether physical or cloud iLok) itself. For example ILM shows I have 160 authorizations but only 135 license assets on my iLok.
Old 04-24-2021, 01:00 PM
yes they are on ilok- didn't get lost.
Plugin authorization issues (7058) in certain projects BillytheB Windows 2 07-26-2018 12:12 PM
Plugin Authorization help. snorgit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-31-2007 07:42 PM
plugin authorization tom devilution 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-03-2007 07:11 AM
Eventide Anthology II plugin Authorization issues Peterjk General Discussion 0 01-12-2007 01:27 PM
plugin authorization yachty 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-22-2006 06:06 PM
