cant hear sound when playing back recording
i have a Imac running mac OS X 10.6.8 with a 2.4 GHz intel core 2 duo processor
and 4 GB 667 MHz DDR2 SDRAM memory. I'm using an onyx blackbird audio interface with pro tools 10. I can record, but not playback the audio. what could be the problem? Also how do I get the audio to playback on the moniters hooked up to the audio interface, and not the Imac? |
Re: cant hear sound when playing back recording
Select the onyx as your playback engine in pt. Check your io routing in the session. To have the onyx used for default audio playback on th imac, select the onyx in the ams under system prefs. Spend time with the manual.
Lincoln Mitchell Pro Tools | latest Mac Mini Server | OSX | Current 16GB Ram | SSHD Apogee Ensemble Thunderbolt |
now i get a message saying the current playback engine does not support a sample rate of 44.1 KHz
Am I to assume your current playback engine is the Onyx? When you say "Now", would it be to much to ask what has transpired. It's hard to make suggestions based on assumptions. Just sayin...
Have you rebooted? Power cycled the Onyx? The more detailed you get the more details you will get.
So...
You can change what PT will use as the playback engine 2 ways... When launching PT hold the "N" key down until you get a pop up window that allows you to select which device you want to use (Onyx, or Built in Output (this is the Imac)). When in a session you go up to SETUP/PLAYBACKENGINE and select your device in the drop down menu. To get the audio out of your Onyx (and into your monitors) you can go up to SETUP/I/O, click on the outputs tab at the top and click the default button (that is once you have the Onyx selected as playback engine). The main output should be outputs 1 and 2 (its the main stereo outputs (Main Out) on the back of the Onyx) |
I hear when recording, but not playing back | gtrgriff3 | Eleven Rack | 1 | 12-13-2012 01:29 PM |
Terrible sound when playing back recording With PT 8.03 | lowlevelowls | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 17 | 12-22-2009 05:37 PM |
Can't hear live midi when playing or recording | mgtube | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 10-30-2009 07:28 PM |
Digi002 do not her sound when playing back a recording | cesemj | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-26-2007 04:48 PM |
How to hear MIDI when playing, not just recording? | floridajohn | Tips & Tricks | 1 | 06-16-2006 07:22 AM |
