Cannot create a fade on one track
I've successfully created fades on all of my tracks except for one. I did them all at the same time but then had to go back and edit this track so the fade was lost. Now when I highlight the section I want to fade and hit Ctrl+F nothing happens. If I cut and paste the last section that I want to fade to create a clip then the Batch Fades screen comes up (and even if I try to use that nothing happens). On all of my other tracks Ctrl+F brings up the Fade Out box which is what I'm looking for.
What am I missing here. This is a simple bass track. |
Re: Cannot create a fade on one track
Is there a tiny little fade out already on it? Blow the view up and check.
Nope - no fade (see attached picture).
Assuming you are talking about the bass track, I would zoom in a lot more to be sure(if there is a fade, it could be only a few samples in length). As Jimmy said, this is the usual/normal reason for not being able to create a fade(its happened to me more than once)
Select across the entire clip and go to edit->fades->delete
http://www.richbreen.com ---------------------------------------- Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6 |
Looks like there’s an edit on the bass track inline with the fade starts on the others. I don’t think PT can select a whole region/clip and fade it.
Start the fade a sample later and it will likely work. Or if possible heal the edit and the fade should work from that spot. Good luck |
How to create a fade the length of a timeline selection? | taylor4814 | Pro Tools 2018 | 3 | 02-18-2019 11:20 AM |
Any way to create fade files in bulk? | Monaco | macOS | 3 | 06-17-2015 07:49 PM |
Can't create fade files (only) | hfth | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-29-2005 01:59 PM |
Can't create a fade | mixit | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 12 | 12-10-2004 06:13 AM |
Can't create a fade out | Ferna | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 07-23-2003 07:01 PM |
