SIP, AFL, PFL Modes in Vanilla 12.1...
Is this an Easter Egg from Avid or something they didn't plan on adding to plain Pro Tools?
I just installed 12.1 on Windows 8.1. Along with the now included individual track input monitoring - and yes the green indicator light is back - under Options>Solo Mode is SIP, AFL and PFL. A quick look in the Reference Manual reveals the following: SIP = Solo In Place AFL = After Fader Listening PFL = Pre Fader Listening And they and the ability to change the AFL and PFL outputs in Setup>IO (which is there) are supposed to be PT HD only. Did Avid slip this into plain PT or is the manual in error or will this disappear shortly? Cheers,
Re: SIP, AFL, PFL Modes in Vanilla 12.1...
intentional. Things they added to the 12.1 release.
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
http://akmedia.digidesign.com/suppor...12_1_85931.pdf Expect more. |
Thanks, I skimmed the Read me a few weeks ago, but didn't remember seeing that. Guess the Reference Manual didn't get changed.
Cheers,
is there a HotKey to change between SIP, PFL, AFL or do we still have to Stop session and go into the menu ??
The front page of the reference manual was updated ;-)
As I mentioned elsewhere, it also still says Heat is for HDX only as it needs DSP to work! Why bother updating the front page to 12.1 if you don't intend to update the contents inside? More incompetence it seems to me.
Mac Pro 2009 with 2010 firmware, 12-Core 3.46ghz, 64gb RAM & working Thunderbolt, OS 10.14.6 and Windows 10 iMac 2012 27", 3.4ghz i7, 32gb RAM OS 10.14.6 Digi 003 Console for control surface only, Focusrite OctopreLE and MOTU Traveler for extra analog-ADAT conversion, UAD Apollo Quad Silver with Thunderbolt card, Apollo x4 and pci-e Octo, Adam A77X monitors. Pro Tools 2022.4, Media Composer 8.9, Sibelius 8.7, Cubase Pro 11, Wavelab Pro 11, Logic Pro X 10.5.1, Mainstage 3. Various apps, soft synths, FX plugins. Plenty of hardware synths, rack gear, microphones etc. And then there's the studio ;-) |
Max Ram for VIs in PT11 Vanilla | jaminjamesp | macOS | 3 | 07-12-2015 04:32 AM |
ProTools11 Vanilla Disabilities | grame99 | Pro Tools 11 | 10 | 02-27-2015 10:16 AM |
What is ''Vanilla'' | ClaudeM | macOS | 9 | 11-12-2014 07:59 AM |
Cost of 11R vs. PT10 Vanilla | morristyson | Eleven Rack | 18 | 05-13-2013 06:50 AM |
Vanilla vs Chocolate | Cloud_9 | General Discussion | 2 | 04-08-2013 08:10 PM |
