Old 02-15-2001, 04:33 PM
Gulliver Gulliver is offline
Default Ticking noise after midi drum notes???
I have Pro Tools 001 on a G4 with a Yamaha DC10 electronic drum set (DTX v2.0).
When 001 plays back the midi drum track (which then controls the brain), I get a ticking sound after each note.
Also, I get the same ticking sound if I click my mouse on the midi notes (which plays them back independently).
Anyone know what I can do to get rid of this?
Thanks.
Old 02-17-2001, 03:10 AM
Mark Haliday Mark Haliday is offline
Default Re: Ticking noise after midi drum notes???
I may have a hypothetical explanation to this. Relating your clicking sound problem with my own issue (see post in the "welcome to the midi conference" thread) all this may come from the way PT ends notes : there are to my knowledge two ways to end a note : the "traditional" Note OFF message, or a very short 0 velocity Note ON message. The latter is favoured by certains systems because it allows a clever thinning out of the MIDI flow (and consquently better timing) through using "running status".(note : this is all I know on the subject, I am pretty ignorant of the details of the MIDI protocol...)
Maybe PT uses that technique. In your case the clicking sound may come from that since drum modules often trigger sounds without taking great notice of the length of the note
I would love some technical answers from digi on that issue
good luck
Mark
Mark Haliday
CUSTOM STUDIO
Paris, France
Old 02-19-2001, 03:37 PM
Mark:
Your problem could be two things:
1 - If you run out of voices on your midi device, it will cut notes off.
2 - If your settings are wrong, your device could be set to cut off when certain other devices are played. An example of this is an open high-hat, which needs to be programmed to cut off when a closed high-hat note is hit.
Old 02-19-2001, 08:46 PM
The ticking noise has mysteriously ended. My guess is an incorrect setting; user error.
Strange ticking noise from the play head Kobra 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-05-2010 05:47 PM
drum pattern to pt instead of just midi notes??? jolita Pro Tools M-Powered (Mac) 3 01-04-2010 11:41 AM
Popping/Ticking Noise in Protools 8 playthemdrums 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 09-09-2009 07:05 PM
popping/ticking noise dlap 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-26-2009 03:56 PM
Remapping Incoming MIDI Drum Notes funkhaus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-28-2006 07:13 PM
