Old 01-10-2011, 07:54 AM
DonaldM's Avatar
DonaldM DonaldM is offline
Default Something like Heat for LE?
Unless I misunderstood something, I believe Avid's Heat can only be used on HD systems. Is there something like Heat that could be used on an LE system? (or PT 9 that isn't HD)
Just wondering...
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones
Owner: Dragon Rock Productions LLC
Dell XPS 435T/9000 Win-10 Pro 24gig RAM
IntelCore i7 CPU 920@2.67GHz
Pro Tools 2019.10
Focusrite Scarlett 8i6
Old 01-10-2011, 08:33 AM
Default Re: Something like Heat for LE?
Yes, HEAT doesn't work without TDM cards. You have some options here with Massey's TapeHead and Steven Slates Classic Console plugin. There are other similar plugins, but those 2 are the first I think of. I think URS has a console plugin as well. Massey and Slate can be demoed for free.
Old 01-10-2011, 08:44 AM
DigiTechSupt's Avatar
Reel Tape and Slate Digital VCC come to mind. I'm sure there are many others..
Avid Audio Tech Support
Support FAQ
Old 01-10-2011, 09:35 AM
DonaldM's Avatar
Thanks Albee and Digi!!!
Pro Tools 2019.10
Old 01-10-2011, 09:37 AM
promixr promixr is offline
Here's a really inexpensive one by a really good company:
http://www.nomadfactory.com/products...tic/index.html
it lists for $129 and you can download a trial : )
Nomad Factory makes really great stuff that is stable and works in ProTools brilliantly...
http://imsproav.com/main/NOMADFMagnetic.html
Eddie Sullivan
Long Island Mac Tech
http://long-island-mac-tech.com
long.island.mac.tech@gmail.com
631 786 3924
Freelance Mac/Pro Tools tech for hire. Metro New York Area.
Old 01-10-2011, 10:03 AM
DonaldM's Avatar
I had forgotten about that one. I know with Heat, that when you use it, it installs on every track, thus treating each track separately, as I understand it, with whatever setting is used. For one like Nomad factory, or the others mentioned, do you put it on every track, an aux track or the Master bus?
Thanks.
Pro Tools 2019.10
Old 01-10-2011, 10:14 AM
I think actually Heat works in sort of an opposite way to a standard plug-in - in that it is treating the sound of the entire mix bus and therefore makes the mix 'gel' a bit more like it would through an analog console and tape recorder system. In a way it's *less* discrete than a plug-in, although you have a certain amount of control over the effect.
You can use something like Magnetic on a single channel, AUX send, or Master Fader or any combination... it really depends on what you are trying to accomplish and what the nature of the program material is. It's merely a way to add the effect of an analog signal chain to Pro Tools, and it could work for you...
My best advice is for you to download it- try it yourself, and see if it makes an effective tool...
Eddie Sullivan
631 786 3924
Old 01-10-2011, 10:25 AM
DonaldM's Avatar
Thanks! I know I read a review of it a while back in one of the mags..Sound on Sound or something like that. I'll just have to give 'em a whirl!
Pro Tools 2019.10
Old 01-11-2011, 01:48 PM
ondruspat ondruspat is offline
From what I understand of it the big advantage of HEAT is how it affects the recording enviorment globally, whereas most the other plugs you have to tweaks channels individually (I think the Slate Digital VCC can be applied globally too).
That being said lately I've found myself really enjoying Massey's Tapehead. It takes a little experimenting but I find it quite nice. In one instance I ran it on a channel I was using for parallel compression on a mix, the compressed sound with nice warmth from Tapehead mixed in awesomely. Very subtle but made a huge difference in the sound.
"Sometimes having limits keeps you sane"- Albee1952
Old 01-11-2011, 01:58 PM
DonaldM's Avatar
Hmm..interesting. I believe I have Tapehead, so will be seeing what I can do with that.
Pro Tools 2019.10
Does comping to a Heat enabled track print the Heat? joshdrucker macOS 0 03-12-2014 10:17 PM
Heat? or Something Like it? Numi Pro Tools 9 24 06-11-2011 06:13 PM
Can I use heat in PT HD 9 with a 003? evertonlouvize Pro Tools 9 11 01-21-2011 09:19 PM
HEAT and PT 9 non-HD chicken Pro Tools 9 1 11-10-2010 06:43 AM
Heat vs VCC nwilson@hns.com Pro Tools TDM Systems (Mac) 24 11-01-2010 05:36 PM
