TYPE 2 ERROR
I'm loading PT fine. I log in to "New Session" fine, after I save my work PT is shutting down and giving me the error. I checked my exstentions and everything seems to be in the right order. did I forget something, I'm stuck...
G4 "the clear and Blue" tower, lots of memory and 2 HD's... "Error type 2 has occurd, please save your work and restart your computer." |
Re: TYPE 2 ERROR
jkereny1:
I had the same problem with "Error type 2, or 11" and finally (after weeks of steadily more frequent crashes) traced it back to (of all things) a bad video card for the second monitor. Soon as I pulled the card (and darkened my second screen) the computer ran perfectly. From all I've heard and went through, Error type 2 solely indicates a Mac problem, not Pro Tools, and it's usually related to memory problems. One source suggested clearing the PRAM. It may be a card, an external drive, internal RAM, etc. I'd try doing a session directly to your MAC drive, with your external drives disconnected and see if that helps . . . Good luck. |
Re: TYPE 2 ERROR
Be prepared to live a life of Type 2 and Type 3 errors. I have had them since day one, tried everything under the sun, cannot fully get rid of them. I have a totally hot-rodded perfectly tuned super-duper system, etc, etc. Things have gotten better over time as I have experimented etc, but the problem is still there. It has something to do with memory allocation. Don't think that adding a ton of extra memory will help... it doesn't, and might even make it worse. I think it's just a flaw somewhere having to do with how PTLE accesses memory... or similar. Or, it could be an issue my 867 Quicksilver Mac I suppose... my friend's Sawtooth machine does not seem to give him as much trouble, though he does get the Type 2 and 3 errors now and then also. Finally, if your system is tuned up well, you should be able to get the error rate down to the point where you will be able to do your audio work without too much aggravation. Remember, the Digi-001 is a $750 recording tool... I guess we can't complain that much. Would be nice not to have those pesky Type 2, 3 errors though... but... work can get done. -imp
Type 2 error.......Please help if you can! | enex6 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 12-28-2004 05:16 PM |
Error type 10,address error ,illegal error, buss error ,illegal instruction | KasticK | Pro Tools TDM Systems (Mac) | 3 | 05-14-2003 11:21 AM |
Buss error,Address error,ilegal instruction,error type 10 | KasticK | Pro Tools TDM Systems (Mac) | 1 | 02-08-2003 05:49 PM |
HELP ! ! PowerBook G4 error Type 3, Type 2 HELP ! ! | Liquidtrek | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-18-2002 06:28 PM |
Error type 1,010 | Ned Bouhalassa | Digidesign Hardware & Software | 1 | 04-17-2002 10:01 PM |
