ProTools 11 and Focusrite
PT won't recognize interface 18i20... drivers are updated so not sure what's wrong... Help?
Re: ProTools 11 and Focusrite
Mac or PC 32bit or 64bit system What OS version We need full details to be able to help Chris
If you use on Mac OS at 96kHz, you should read this thread http://global.focusrite.com/answerba...96khz-on-a-mac |
Go here: http://beta.focusrite.com/
Pro Tools 10.3.10, Cubase Artist 7.5.40, Allen & Heath Qu-16, Focusrite Scarlett 18i8 2G, Fujitsu Lifebook AH532, Intel Core i7-3612QM, 8 GB RAM, Windows 7 Professional SP1 64 bit |
Try setting the computer to NOT route all audio thru the FR box. Once you get it working with Pro Tools, then you can try routing other audio thru it(best to simplify things for troubleshooting)
What driver are you using for the interface? Some drivers are only for Yosemite, others for ML.
When booting, hold down "N" and make sure you have selected the correct driver. Need more info on your system. Simply saying "it doesn't work" doesn't give enough info.
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
Hi jdcable,
As hooksound mentioned try out this version of MixControl that has an updated driver: http://beta.focusrite.com/releases/scarlett_mixcontrol/ |
focusrite interface with protools | DJ_Jyra | Third Party Interfaces | 23 | 12-30-2014 08:45 AM |
Using Focusrite Saffire Pro 24 with Protools 10.3.5 | aussie45 | macOS | 6 | 06-25-2013 05:42 PM |
Focusrite Liquid Mix and ProTools 9 | playground_strifer | Pro Tools 9 | 1 | 03-25-2011 03:20 AM |
focusrite interface with protools ? | dubhole | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-22-2009 05:56 AM |
Protools and Focusrite ISA 430 a/d card | Hanslemonverm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-10-2005 08:57 AM |
