Old 04-23-2001, 06:11 AM
bvleugels bvleugels is offline
Default playback setting
I run 5.1 with OS 8.6 on a 9600.
I'm trying to find the Preference buttion to reset my playback setting...I'm used to the playback setting of playing a region on anywhere in a session FROM THE POSITION OF MY CURSOR. No, after stopping the playback, it will start from where I stopped, NOT from the location of my cursor.
Where is the setting to change this back? I can't seem to find it anywhere.
Thanks,
Bart
Bart
Boom Audio
Old 04-23-2001, 07:57 AM
Jeffrey Talbot Jeffrey Talbot is offline
Default Re: playback setting
This goes under the "oops" catagory..
In the "EDIT" window, above the Show/Hide window are three icons.. The right most one has four arrows... make sure this is highlighted, and you will be back to operating as you were before.
Good Luck!
Old 04-23-2001, 08:07 AM
savage savage is offline
Go to menu <operations>, choose <scroll options> and there you go.
Old 04-23-2001, 08:10 AM
sorry...guess I misunderstood you.
Old 04-23-2001, 08:34 AM
snoopy snoopy is offline
I think there is a bug that causes one of the preferences to keep turning itself on every now and then. I have had this problem since 5.0 and was hoping they woulkd fix it in 5.1. I forget the name of the preference, but its the first check box in the operations prefs tab i believe.
Colin Miller
Teaboy Audio Recall Sheets
http://teaboyaudio.com
Old 04-23-2001, 10:17 AM
spigots spigots is offline
Or it could be this.
Setup>Preferences>Operation
Top Radio Button is "Timeline Insertion Follows Playback"
De-select it
Old 04-23-2001, 11:56 AM
Przemek Przemek is offline
I think that the problem is that it's very easy to accidentaly switch this function on and off by pressing ctrl+N - or even easier, if someone uses one-key commands. If this happens, press ctrl+N and you're done.
Przemek.
http://imaginatlh.com/91709
Old 04-23-2001, 06:11 PM
I meant what spigots said, thanks for the correction (I don't have online access at studio to check things like that). Przemek, you may be right about the one button accident. Do you know off hand what letter it might be that puts it in that mode? I guess I never considered that because I didn't think they affected anything that went into the preferences (since it would have to be saved into the preference file each time as opposed to a pull-down menu option).
Colin Miller
Old 04-24-2001, 01:17 PM
jimlongo's Avatar
jimlongo jimlongo is offline
It's the N key in one key mode. So easy to hit by mistake. It should be changed to another key or at least there should be a visual clue that it is on...some kind of indicator which mode you are in.
noise | jimlongo
Old 04-26-2001, 08:53 AM
I looked into this issue a little more recently (In regards to me).
The "Timeline Insertion Follows Playback" preference keeps checking itself. I can't recreate this by using the N key or Ctrl+N. Also these two buttons do not remedy my problem either, only deselecting "Timeline Insertion Follows Playback" from the prefs does. The button with four arrows is always highlighted when working and not working properly.
Also wondering if anyone else has this problem. I'd say every 25 or so punchins, pro tools does not go into record. The record light will flash and then go solid, but the selected region will not actually record. This occurs in both regular and quickpunch mode, using F12 or CMD+Spacebar.
Anyone else?
Colin Miller
Setting markers while recording or playback. critza 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 01-22-2010 06:30 PM
Help Setting Up Playback Engine hearttimes Pro Tools TDM Systems (Mac) 1 08-03-2007 05:45 PM
setting up repeat playback? chal7ds 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-13-2006 04:38 AM
Setting up output for playback mcm15 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 01-07-2006 02:47 PM
Pausing playback or setting locates STUDIO A 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-26-2003 11:38 AM
