Old 12-08-2020, 08:51 AM
rossi68 rossi68 is offline
Default Buying used pc
I can pick up a used gaming pc with these parts
for around 400$
i7 6700k
MSI z170A
16 Gb ram (only 1200 MHz)
Nvidia Geforce gtx 970
Will it be a significant step up from my i7 980x pc?
Antelope Orion Studio 2017, UA 4-710, Presonus digimax FS, Sony DMX r100
Old 12-08-2020, 10:11 AM
junkgear's Avatar
junkgear junkgear is offline
Default Re: Buying used pc
I'm assuming you mean Pro Tools performance.
If you are already using SSD drives in your current system, then no, I don't think you will see a drastic improvement.
Overall, the new system will be more responsive, and programs will load faster, but those old processors were pretty powerful and once PT is open and running, I don't think you will see much difference.
If you are running into issues running your sessions, let us know a bit more about your full set up and how you are using PT and we can try to guide you to a better system.
Will
System Details
Old 12-08-2020, 10:57 AM
The Weed's Avatar
The Weed The Weed is offline
i7 4770K, 4th generation quad core, on an ASUS Z87-Pro motherboard. Just did the last upgrade I can unless I upgrade the video card: Samsung 970 Plus NVMe drives and from 16 to 32 GB of RAM. Computer is 7 years old and should last another number of years.
I don't stress the system very much as normally I'm just recording my voice for projects, but I also do described video, so have video, sound track, plug-ins and a producer's track so they can remote direct, at 64 buffer. I've also mixed a small movie - all with some Waves plug-ins and at 64 buffer when I had spinner hard drives and 16 GB of RAM.
As Will mentioned, let us know what you have now - a Sandra report would be good - and let us know what issues you're having and your typical session and its requirements.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 12-08-2020, 02:26 PM
I was just wondering if the sixt gen cpu would be better than the first gen really.
I ended up returning a new pc this summer. A i9 10900x. Expensive... almost 3000$... of course better than my old one, but I felt it could not justify the price...
But if I get better performance for 400$ that would be something to think about.
Old 12-08-2020, 04:16 PM
You should be able to bag a used HP z820 off of eBay. I had one that was dual 6 core XEON's at 3.5GHz, 64GB of RAM, nVidia graphics and a 500GB SSD loaded with Windows 10 Pro for $1100, shipped to my door. Tossed in my audio and samples drives and my HDN card and it ran like a train I did need to add a USB3 card(for more ports) and a Behringer USB>SPDIF box for Windows sounds and I swapped the graphics for a card I had that would drive 3 screens.
Old 12-08-2020, 05:59 PM
ejinbc ejinbc is offline
Originally Posted by rossi68 View Post
i7 6700k
OP
I don't think you'll see a significant difference - the exception being if you routinely run long chains of CPU-intensive plugins that saturate one of the cores - the single core performance improvement between the 2 CPUs you mention is significant (see below).
I use PassMark for doing CPU comparisons - PassMark corelates reasonably well with DAWBench (a good Audio-specific Benchmark). In the images attached you can see that the overall PassMark is not that different between the 2 CPUs (980x vs. 6700K). I personally waited to upgrade from a 3700K until I could get an 8700K because there was no compelling reason. The 10900K has pretty good performance improvements, BUT you would have to be silly to buy a new Intel CPU right now - the M1 and AMD 5950 make Intel's top end look sad - one for core count and single core performance, and the other for power efficiency. Intel must have an interesting response soon. Competition is good.
Hope that helps. YMMV
ejinbc
Old 12-08-2020, 06:20 PM
EGS's Avatar
EGS EGS is offline
According to this, you'd theoretically pick up about 10%: https://cpu.userbenchmark.com/Compar...0K/m3336vs3502 Wait to upgrade if you can. The CPU battles are hot right now, thanks to Apple and AMD. I'm currently running ProTools on an i7-980x with a slight OC to 3.9Ghz. It's working well, but it's not exactly a modern monster! This CPU (or similar) would give you about 34% more juice: https://cpu.userbenchmark.com/Compar...m3336vsm929964
Click for audio/video demo
Click for resume
Old 12-09-2020, 07:49 AM
mikahawkins1 mikahawkins1 is offline
The specs look good. The price is all that matters now.
Old 12-09-2020, 09:15 AM
From my own experience:
Moving from a X58/980X system to an X99/6800K system was a pretty serious jump in power. The problem for me was poor stability. I fought with the X99 rig for several months before I bought the HP z820, which was solid as a rock. If you're still bent on the 6700 rig, the motherboard/chipset can make or break things. To me; that motherboard is a giant unknown
Old 01-01-2021, 02:10 PM
Interesting.. The HP Z820 is from 2009?
There is a computerstore here in Norway trying to sell one for 3500$....
I offered 500, so we sill see :)
Buying PT 10 djmichael.london macOS 7 02-18-2013 02:15 PM
Buying a Mac Rizzle Pro Tools M-Powered (Mac) 9 10-12-2008 01:13 AM
buying a new mac kds 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 10-21-2004 04:53 PM
HELP! I am buying a Dell Laptop with intent on buying a DIGI 001 as well xian$ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 01-18-2003 11:53 AM
buying a used 001 JFogarty 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-17-2002 12:13 AM
