Roland Octa Captures X 2 and PT 10.3.9
I have 2 x Roland Octa-Captures (as an aggregate) through a powered USB 2.0 Hub with Pro Tools 10.3 Macbook Pro OSX 10.8 Latest Roland drivers all around and a 24 channel Board. I'm Using the direct inputs on the Octa-Captures and Ive got a snake of balanced 1/4" TRS from the OCTA-Capture's outputs (1-8 on both) to the XLR Inputs on the Mixer. Everything works with one unit (8tracks)
I simply want 16 x inputs and 16 x direct outputs (8 ins and 8 outs on each Unit) to my hardware mixer. Pro Tools recognizes both units but I have to rename everything on one of the units because PT won't let you have 2 channels named the same. Tried the defaults with no success. I created a new I/O setup with 16 mono inputs and 16 Mono outputs. Channel 1 input goes to output 1 but the routing makes no sense as channel one on the first Octa-capture comes back as channel 13, also PT sees channels named 11 and 12 on both units that don't exist. Spent hours troubleshooting already.
In Short, I would like to arm 16 channels directly into the Octa-Captures, Hit Record, and then Playback 16 channels through my Hardware mixer.
