Old 05-10-2022, 06:53 AM
pgstudio pgstudio is offline
Default Avid Control App - Meters Yellow and Can't change
Hi Guys,
Since the last update, the meters on my Avid Control App (Dock) changes to yellowin Cubase. If I close the app and open it again it turns back to blue (or green, depending on what I chose on the options).
What seems to trigger the "new" color is an ALT TAB to other application and then going back to cubase.
Let's say I'm mixing a session, then I go to finder (and the Eucontrol app changes everything to work on Finder), once I go back to Cubase, it changes to control cubase and now the meters are yellow.
I did the same testes in Pro Tools and it worked well. It seems to be something related to Cubase only, I don't know.
If I switch back and forth between Cubase and Pro tools, Cubase is Yellow and when I go to Pro Tools it's blue.
This thing only happens in the App on my dock. The apps on the S1 (My setup is 2x S1 + Dock) use the correct color.
I'm sending a screenshot of that problem
Is anyone having this issue ? Is it a known Issue ??
Thanks!
Avid Control: Meters in monitoring tab JanuS Avid S1, S3, Dock and Control App 0 10-31-2020 03:11 AM
RMS Meters Don't Work On Control APP and Meters Lynn Gräber Avid S1, S3, Dock and Control App 0 02-18-2020 02:02 PM
Avid Control, Meters not working on iPhone 8 bsteeve Avid S1, S3, Dock and Control App 8 12-11-2019 11:17 PM
Mbox2- PTLE 8.0.1 meters frozen on yellow hal52 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-25-2010 12:00 PM
Is it possible to change the scale of the audio meters? Marcel Risberg 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-03-2008 03:34 PM
