Old 07-29-2016, 07:02 PM
tenknuckles tenknuckles is offline
Default Import audio: "same unique identifier, ProTools must stamp" .. then plays wrong audio
I have a session where I started by importing a WAV file about 50 minutes long. The first import worked.
After that, I have tried to import new audio files into the session. Every single time I get the message that the file "has the same unique identifier as a file already in this session. Pro Tools must stamp this file with a unique identifer in order to use it".
So I go ahead and click the "Stamp File" button. Then what happens is that the newly imported audio clip will not play the correct audio when I put it into a track ... it instead plays the audio from the first imported file!
I noticed that when I try renaming the clip, I can see that under "Clip Info" the "Parent File" is, in fact, the first imported file, not the file I imported. (And it makes no difference if I import it to the clip list or to a new track.)
I've tried importing files with different formats (like MP3) with the same result. And when I select "Reveal In Workspace" and play the file from there, it actually plays the correct audio.
This is a pretty obvious bug and a bad one, at that. Audio import to a session is completely broken for me after the first import.
I'm using Pro Tools 12.4 in Windows 7 (64 bit).
BUG: Stamp File Unique Identifier Crash reichman Post - Surround - Video 0 12-04-2009 10:47 AM
"audio engine plays starup deadline was missed" message in pt 8 nachonieto 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 05-31-2009 02:34 AM
Audio file "has the wrong unique identifier"? el biciclista Pro Tools TDM Systems (Mac) 3 07-09-2005 10:51 PM
Help: FILE HAS THE wrong unique identifier Alécio Costa Pro Tools TDM Systems (Mac) 13 08-21-2002 12:07 AM
wrong unique identifier message, can't find audio mstucker Pro Tools TDM Systems (Mac) 7 04-18-2002 10:11 AM
