Old 03-15-2012, 01:33 PM
SteveGam SteveGam is offline
Default Possible for hardware insert to be post fader
Hi all,
Using a Dugan mixer and although I have a workaround I was still wondering if there is a way to make the hardware inserts post fader.
thanks,
Steve
Working for the preservation of quality live sound.... One show at a time!
Work
Twin S6L's
PM-10
Profile, D-Show
3 Midas Heritage's and 5 M32's
Several other analog and digital consoles
d&b J Systems
L'Acoustics V-Dosc systems
Home: Compaq Z800
Dual XEON hexes
48G Ram
Windows 10
Midas M32 and XL48
Genelec 8050's with Genny sub
Genelec 8030's
JBL L96 & LSR32
Old 03-15-2012, 05:25 PM
Nicolas Lowman Nicolas Lowman is offline
Default Re: Possible for hardware insert to be post fader
I don't know that there is a way to make the HW inserts post fader.
If there isn't, a workaround if you have enough channels would be the following
Unassign your mics from the the stereo bus. Let's call these 1-8.
Use your microphone channels (1-8) to send to the direct outs, set the direct output post fader, patch the direct out of the channel to the FOH 1/4 TRS that is feedi g your Dugan.
Now go to the next layer down in the desk(say 25-32), patch the input of these channel to your FOH inputs from the Dugan. Make sure that these channels are assigned to he stereo bus, set the faders to 0 and leave these channels alone.
You will do all your mixing on channels 1-8. This is a roundabout way of getting there, but I think it is gonna be the only one that you will find.
Moderator if there is a way to change the HW insert point, please send my response to file 13!
Nicolas
Old 03-15-2012, 05:28 PM
Sheldon Radford's Avatar
Sheldon Radford Sheldon Radford is offline
Nicolas beat me to it. There isn't a way to make the HW insert points post-fader, but the Direct Out pickoff trick works great.
Here's one simplification: rather than loop out/in through the physical TRS connectors, add eight simple plug-ins to the rack (such as a lightweight EQ3), route the Direct out of ch 1-8 to each plug-in, and return each plug-in's output to ch 25-32. Bypass the plug-ins so they're not inline. This approach essentially creates an internal loopback.
Sheldon
Old 03-15-2012, 07:11 PM
This is one of those instances where it would be very ideal to have the option to move the HW insert, as there isn't a really a good substitute for them.
They seem to pretty much be the cat's meow for discussions with multiple people.
http://www.dandugan.com/who-uses.html
Old 03-16-2012, 10:55 AM
Thanks for the replys. Just for the record I unassigned the channels from the ST bus and sent each to a group. Placed the Dugan on each group and sent to groups to L/R.
works like a charm and didn't need the groups for anything else
Steve
Work
Twin S6L's
PM-10
Profile, D-Show
d&b J Systems
Home: Compaq Z800
Dual XEON hexes
48G Ram
Windows 10
Midas M32 and XL48
Genelec 8030's
JBL L96 & LSR32
Old 02-03-2015, 03:06 AM
kristianberg kristianberg is offline
The problem for me is when I choose Post Fader for the Input Strip Fader Pickup Point, to be able to send Post Fader direct out to Dugan, I´m not able to send a Pre Fader to the PQ User Inputs. So I can´t send a Pre Fader - Post Mute to the musicians.
I have no more busses in spare.
Any solutions to this? - other than the possibility for hardware insert to be post fader, which would be great
Kristian
Hardware insert bypasses fader...?? MichaelK Pro Tools 11 2 01-05-2014 12:57 PM
How can I make hardware insert pre or post fader P,B,S Pro Tools TDM Systems (Mac) 10 12-02-2012 08:05 PM
Hardware insert--No audio going to 1-2 master fader. Paul Cavins 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 11-06-2008 04:59 PM
Logic behind post fader insert on Master Buss? McMasters Pro Tools TDM Systems (Mac) 10 09-17-2004 08:07 AM
Hardware insert on master fader feeds back? KK Proffitt Pro Tools TDM Systems (Mac) 6 03-19-2004 01:53 PM
