Old 02-08-2012, 02:52 PM
sounds_good sounds_good is offline
Default D-Show with MADI and Roland IEM
I'm part of a team of folks who are planning an upgrade to our church's audio system. We currently have a Yamaha PM5D and use Avioms as our IEM system, but we're wanting to move to Venue D-Show. We're also wanting a more robust and flexible IEM system. Enter the Roland IEM system with their M-48 personal mixers.
I really like the way this looks on paper, but I'm stuck on 1 problem. With this Roland system it can utilize 40 channels/outputs to slice and dice those any which way for each personal mixer. The most streamlined solution is to utilize a MADI option card out of the Venue to an S-MADI bridge which then feeds the Roland system.
My question pertains to the MADI option card. I've seen where the MADI strictly passes inputs 1-48 plus 16 assignable outputs, but I have a sales rep telling me that within Venue I can route whatever 40 channels/mixes I want out the MADI card.
Obviously I don't want to make this major purchase without knowing exactly how it will work. So, can we dictate what 40 channels/submixes go out the MADI card to Roland, or is it strictly inputs 1-48 (or really 1-40 since that is all Roland will see is up to 40)?
Thanks in advance for your help!!
Old 02-08-2012, 03:57 PM
Sheldon Radford's Avatar
Sheldon Radford Sheldon Radford is offline
Default Re: D-Show with MADI and Roland IEM
THe VENUE MADI output card passes stage inputs 1-48 as MADI channels 1-48, plus 16 fully assignable outputs as MADI ch 49-64 (via the patchbay).
From looking at the Roland manual, there are configuration options to choose which range of channels are available on the REAC ports (either 1-40, or 41-64, if I read it right). This means you could use the 16 assignable channels as sources, plus stage inputs 41-48, I believe. Check out the user guide for more details, this may just do the trick:
http://lib.roland.co.jp/support/en/m...S-MADI_e01.pdf
Sheldon
Old 02-08-2012, 06:50 PM
BradLyons BradLyons is offline
Sounds Good,
Where is your church located? Have you used/seen the Venue in action in person?
Thank you,
Brad Lyons
www.howavl.com
Old 02-08-2012, 08:02 PM
Sheldon,
I was afraid of that answer. Seems there is not an easy, clear cut way to get this done. We can't simply use the 1-40 inputs, and if we use 41-64, while that does provide more options than the Aviom alternative, it doesn't come close to using the full potential of 40 inputs that Roland can handle. With the cost of Roland significantly higher than Aviom, we definitely want to use it to its full potential (if we do go that route).
Brad,
I am in Omaha, Nebraska. Yes, I've seen the Venue in action. One of our sound engineers implemented a D-Show and PT HD rig with C24 at another church, so his input has been great. But we just don't know anyone that has used the Roland system, so it has been difficult trying to piece together how to get this Roland IEM system to utilize its full potential with Venue (or really any non-Roland digital board). Looks like it would be very clean and simple if we were using a Roland console, but we're going with Venue.
Do either of you have thoughts on how we can make this work to utilize the full potential of 40 channels into Roland while giving us some flexibility to assign what 40 channels/submixes to assign?
Thanks again for your expertise.
Old 02-08-2012, 08:42 PM
Jim Roach Jim Roach is offline
Here is some info about the Roland system used with a Digico SD8. Maybe you can find some of it useful with Venue.
Personal Mixing 2.0
M-48 FAQ's
Old 02-09-2012, 12:27 AM
Tragic Dog Tragic Dog is offline
I too have been looking into this.
Some ideas I've come across, but have not had time to investigate are MADI matrix routers
http://www.solidstatelogic.com/music...i-x8/index.asp
http://www.directout.eu/en/products/m.1k2.html
Google Search
If you find out anything please let us know.
Jon Lillie
Behind the Light Productions
PT 10-CPTK-Motu Traveler v1
Mac Pro 2x2.8GHz Quad-Core, 14gigs of ram
Macbook Pro w/Retina Display, 2.3Ghz i7, 16gigs of ram
Old 02-09-2012, 12:47 PM
Nicolas Lowman Nicolas Lowman is offline
A lot of the RME MADI devices have a routing matrix in them as well. That may also be an option.
http://www.rme-audio.de/en_products_adi_642.php
Have you had a chance to play with the Roland system? How does it sound compared to the Aviom system?
Old 02-09-2012, 03:10 PM
personally, I'm told it sounds better (i have not heard it, but i weekly run an aviom system), on paper it is by far a more advanced system that should be considered if doing self mixed IEMs.
Jon Lillie
Old 02-10-2012, 07:26 AM
Same here. I've heard & read good things about how it sounds and the functionality is great (once you get the 40 channels into it ), but I haven't heard it personally.
We currently run Aviom and it is just too limiting. It seems Aviom is the standard that everyone talks about, but I can't believe they haven't come up with a solution so that everyone isn't limited to the same 16 channels. We will stick with Aviom at our satellite location. It works perfectly fine in a smaller setup, plus Roland is definitely a good bit more expensive, so it helps the budget to keep them on Aviom.
Tragic Dog, thanks for the tip on the SSL MADI-X8. That looks like it will solve our problem.
Old 02-10-2012, 10:36 AM
Excellent, if it works please let us know.
Jon Lillie
HD MADI Supports Frame Pattern MADI ??? misterGOLD Pro Tools HDX & HD Native Systems (Mac) 2 02-10-2014 11:43 PM
AVID MADI - connect 2 MADI units? smc917 Pro Tools TDM Systems (Mac) 4 07-25-2011 02:38 PM
Feeding Madi from Soundcraft VI-6 to a Venue D-Show Henning Svoren VENUE Live Sound Systems 5 07-24-2011 10:15 PM
VENUE D-Show using MADI-Card and FWx-Card in FoH-Rack Zacha VENUE Live Sound Systems 6 07-02-2011 07:04 PM
How do I get my Roland xp30 to show up on midi inputs surchur 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-31-2002 12:55 AM
