Old 06-17-2011, 09:39 PM
Kenmillerjr's Avatar
Kenmillerjr Kenmillerjr is offline
Default Authorizations of Plug-Ins
Okay, What am I doing wrong?
I purchased ML4000. Added license to iLok. Put iLok in. Installed on console. It won't authorize. Wants to use a license card or challenge question. It will read all other authorizations on the iLok, but not the ML4000. I've even tried adding the license to another iLok, no success. I've tried installing both the ML4000 for PT and Venue; neither works.
The hardest part about these consoles seems to be getting plug-ins installed and authorized. In the past I've spent about two hours dicking around with everything.
Ken Miller, Jr.
Audio Engineer
Southside Baptist Church | Warner Robins, GA
| VENUE Profile 96X64 with MADI Option | ProTools 7.4.2 HD3 Accel PCI | ProTools 10 Native | MacBook Pro 17" OS 10.7.1 2.3GHz Intel Core i7 8GB Ram | Mbox 2 Pro | Mbox 3 Pro | Motu 896mk3 Hybrid |
Old 06-18-2011, 12:07 PM
Brent Lind Brent Lind is offline
Default Re: Authorizations of Plug-Ins
Ken, I've been through this, it's most likely that between the software and the ilok, one is the "HD" version and one is not. Get HD for both if you can and you should be in business.
Old 06-19-2011, 11:38 AM
Nicolas Lowman Nicolas Lowman is offline
If you have the correct license, then it is likely an ilok issue. I would suggest downloading the ilok driver update from pace. This often takes care of any issues that I have. Incidentally I have done this several times on different desks with the ML4000 as it is a plugin that I use often.
Nicolas
Old 06-19-2011, 05:14 PM
Nic-
I downloaded the most recent iLok driver from pace still with nothing. Are you using the HD version of ML4000 or Venue version?
Ken Miller, Jr.
Audio Engineer
Old 06-19-2011, 10:03 PM
dstagl dstagl is offline
Did you recently purchase this? Did you get a license for version 4 or version 5? Currently, version 5 will not work with Venue. Last I heard was Q3 of 2011.
You should contact McDSP. They're usually really good for helping out with this sort of thing. If you purchased v5, they can probably get you something that will work now until v5 is working for Venue.
Dave
David Stagl - Mixer | FOH Engineer
http://www.staglproductions.com
http://www.goingto11.com
Old 06-20-2011, 11:16 AM
Touchwood Studios Touchwood Studios is offline
McDSP will give you a Temp V4 license they did it for me.
Plug Ins need new Authorizations or what??? japple macOS 3 06-25-2013 05:19 AM
Plug-ins do not remember their authorizations digimido 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 03-14-2008 08:20 AM
Plug in authorizations TAF Pro Tools TDM Systems (Mac) 4 09-19-2004 09:14 AM
Plug-ins losing authorizations Up Late Pro Tools TDM Systems (Mac) 2 11-10-2002 02:18 AM
Plug In Authorizations Cliff Adams Pro Tools TDM Systems (Win) 9 09-08-2001 08:36 PM
