3Gb switch
Could you guys lead me to an explanation and is it 8 only or will it work in 7.4?
Re: 3Gb switch
in 7.4 you have to patch PTLE and modify the boot.ini file. in PT8 the program is already LargeAddressAware so you only need to modify the boot file
bassist...deep pocketz anyone???!!! The Basschakra Lucid Soul Trip i7 Builds - Specs and Results HDNative | Omni | i7-3930K OC'd 4.0GHZ | ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff |
Re: 3Gb switch
Thanks Myhkal, is there a how-to somewhere? I poked around quite a bit and never found it. I'll google as well.
Re: 3Gb switch
here ya go... http://duc.digidesign.com/showthread.php?t=212853
Re: 3Gb switch
Thank you, maybe I had stumbled across that but now I understand it better.
Re: 3Gb switch
here is another good link that i have posted in the past too. there are more links in the page too... http://support.microsoft.com/kb/291988
Re: 3Gb switch
Be sure to set up your boot.ini file to give you the option at boot up to use or not use the switch. Depending on how you system is set up the switch can induce instability. The size of your video card is primary among the variables (the smaller the better). If the switch proves unstable you may need to alter your hardware setup or use the USERVA switch to give a little extra RAM to the system.
External talkback mic/switch/cuelight switch | Pete Gates | Post - Surround - Video | 3 | 03-16-2011 01:53 AM |
If I switch from PC to Mac... | Rammelt | Pro Tools TDM Systems (Mac) | 3 | 03-08-2008 09:35 PM |
Switch Mac Mbox to Windows - and then switch back | bluesigns | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-07-2004 09:50 AM |
OT: Best USB KVM switch for Mac and PC | valvebrother | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-01-2002 02:51 PM |
Using a Switch instead of a Hub | osman | ProControl, Control|24, Command|8 | 3 | 01-25-2001 04:13 PM |
