What would u do? Main vol knob on 001 stopped resp
Main volume knob on my digi 001 was working fine then one day..I can't adjust main level thru 001. All the other knobs work. Is there something simple I'm missing? Should I open her up? What would u do?? Thanx
Power Mac G4 733 640MB OS X 10.2.8 PT LE 6.1.2 digi 001 REASON 2.5 |
Re: What would u do? Main vol knob on 001 stopped resp
two options:
1. Go to Rad Shack and buy the spray bottle of contact cleaner. Open the unit and spray out the inside of the potentiometer (that which the knob is attached to). Rotate the knob as you spray and let dry. 2. Go on eBay and see if you can find the hardware only for a reasonable price. 0. Call Digi tech support and see if they will still fix the OO1. |
[QUOTE]
two options: 1. Go to Rad Shack and buy the spray bottle of contact cleaner. Open the unit and spray out the inside of the potentiometer (that which the knob is attached to). Rotate the knob as you spray and let dry. Is that safe???
It's a little on the greasy side, but I've restored the pots of my 20 year old Lexicons without a hitch.
MBox 2 Pro Monitor knob has stopped changing monitor levels | Rumandolin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-21-2013 09:13 AM |
Fast Track Ultra - Main Output Knob Stopped Working | danimal423 | FireWire & USB Audio Interfaces (Mac) | 12 | 04-18-2013 11:57 AM |
Fast Track c400 low volume cut-off by main knob | MikeyC | FireWire & USB Audio Interfaces (Mac) | 7 | 04-09-2013 03:41 PM |
Main volume knob...is it just like the 002R? | Gothboy | ICON & C|24 | 1 | 05-09-2010 07:29 PM |
Replacing the Main Monitor Level KNOB! | a2zproductions | ICON & C|24 | 4 | 11-01-2008 09:35 PM |
