Help!!! Problems Recording Vocals!!!
Its probably something simple but i dont know why when i am recording vocals theres a delay from when i speak into the mic to when i hear it in my headphones or speakers? what do i do to fix this? I can say "hello" and then it will take like 2 seconds before i hear it in my headphones when im recording..
help please.. thanks, dennis |
Re: Help!!! Problems Recording Vocals!!!
that delay is called latency. when you record vox you set your
playback buffer to 256. when you finish you should switch back to your previous setting
Gear> C8, 002, Trigger Finger, Kontrol 49, Apc 40 SW > Pt 8, Reason 5, Recycle 2.1, Ableton Live Suite 8.02 Plugs > All Registered plug in's & Vinyl out the wazoo. Mp3 sucks |
Even 256 may be a little much so try 128. If you are using a DIGI002, you can use Low Latency Mode while you record(if you do not need plugins or aux sends on the new track WHILE you are recording).
Vocals: Mic Signal & Recording Problems Mini M-Box | tabikat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-17-2010 11:59 AM |
Help With Recording Vocals | BPM | Tips & Tricks | 2 | 10-23-2009 09:06 PM |
Pro Tools LE 7 Recording Vocals Problems.. Help!! | dmt2828 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 12-29-2007 12:45 PM |
RECORDING VOCALS | soulivar | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 07-06-2004 09:38 PM |
recording vocals? | june bug | Tips & Tricks | 3 | 10-08-2002 04:19 AM |
