Old 01-28-2011, 05:09 PM
BenDorigan BenDorigan is offline
Default awful sound when arming track for record
I recently installed ProTools LE 8 with the Mbox 2 mini interface on my Mac G5. Too often when I click the record button to arm a track, the light meter on that track pegs out (mix window) and a deafening screech blasts through my headphones. (I make sure they're off my head before I click record now.) I can occasionally remedy this by restarting the computer but doing so each time gets counter-productive. Any advise?
Old 12-08-2012, 09:15 AM
Zicky94 Zicky94 is offline
Default Re: awful sound when arming track for record
I get the same problem in pro tools 10 with a focusrite 2i2. Please help!
Old 12-08-2012, 09:58 AM
YYR123's Avatar
YYR123 YYR123 is offline
Default
To zicky b/c Ben's post is
So old
Check ur levels turn your gain pots all the way down -
Make sure ur routing is correct in ur I/o setup
If its screeching on mic input switch to line to see if it stops
As always latest drivers for the 212 and latest asio drivers as well
Daniel
Old 12-08-2012, 01:27 PM
JazzyJ JazzyJ is offline
mute the track!
You're using an mbox mini with a 'latency mix knob'! You monitor there, NOT through Pro Tools.
Read the manual.......
Hack Pro (4.2Ghz i7 Quad/16GB)
PT11 / OSX 10.8.5
TC Electronic Konnekt 24D
Old 12-09-2012, 11:01 AM
Ben Jenssen's Avatar
This has come up before. Some have said it's not feedback, that it behaves like some kind of bug.
I think someone solved it by just trashing prefs. Worth a try.
PT embedding awful, awful noises into my audio. Houston, we have a problem.... emorganproductions 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 02-26-2010 02:41 AM
hear sound without arming track?? tec 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-13-2007 09:22 PM
Awful Sound Quality After Bounce NikKnights 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 05-23-2004 08:20 AM
"PT makes your mixes sound awful"-? chuck General Discussion 9 05-14-2001 08:46 AM
