Old 01-18-2002, 01:33 AM
PHead14006 PHead14006 is offline
Default Track Arming AJ-D450 DVC-PRO
I have found that the Panasonic AJ-D450 DVC-Pro deck needs to be armed on channels 5 and 6 in order to do a ch. 1-2 insert edit, with the record tracks set to 8. If you set the record tracks to 3 and arm only 3 it will arm the time code track, and if the TC isn't set to internal regenerate you will burn a hole in the TC stripe. This can be repaired by editing over the gap on 3ch/ch. 3 with the deck set to internal regen.
Just thought I'd share this delightful tidbit.
I Keep A Vigil In A Wilderness of Mirrors (Fish)
Old 01-21-2002, 11:33 AM
DigiTechSupt's Avatar
Default Re: Track Arming AJ-D450 DVC-PRO
Phead,
What version of Pro Tools are you using?
If you have not already upgraded to 5.1.3 you should, a lot of work has been done to Machine Control and this may resolve this problem.
If you are already using 5.1.3, and please let me know if you are, we need to get this info up to Digi so they can check it out.
Thanks,
Jon Connolly
Digidesign Product Specialist
Avid Audio Tech Support
Support FAQ
Old 01-21-2002, 11:58 AM
I am using 5.1, a very early version. In my Peripherals>Machine control panel the only deck displayed on the machine "personality" menu is BVW-75. I understand that the functionality of Machine Control is part of Pro Tools and different versions of PT give different choices on this menu.
HTML code is On
track arming question fork-media Pro Tools 10 2 07-02-2013 08:21 PM
SRW-5800 HD CAM Track Arming JJD_EVOS Pro Tools HDX & HD Native Systems (Mac) 2 01-10-2013 01:21 AM
D5 Track Arming Profile?? admix Post - Surround - Video 3 04-13-2006 12:06 PM
Command 8 track Arming The Chinese ProControl, Control|24, Command|8 2 12-21-2004 01:57 AM
remote track arming aristotle Pro Tools TDM Systems (Mac) 3 05-20-2002 04:33 PM
