Old 03-01-2014, 08:08 AM
DonaldM's Avatar
DonaldM DonaldM is offline
Default Routing Audio Out of Transfuser Issue
I'm trying to route the audio from a specific module in Transfuser. Here's the set up:
Transfuser instantiated on an instrument track
3 modules instantiated within Transfuser with complimentary grooves
Modules 1&2 have their audio outputs routed to MAIN
On module 3, I selected Audio output 1
Set up an AUX track and selected Transfuser Audio input 1 as the audio input for the AUX track.
Problem: The audio from Module 3 is still go to the MAIN and is audible only on the Instrument track. NOthing is going to the AUX track. I can't figure out why. As far as I can tell, I went step-by-step to what the manual said for routing audio. The manual says that audio from a module will not go to the MAIN output if it is selected as the INPUT on a PT AUX or AUDIO track. But it is! I know I've done this in the past, but that was before the upgrade to IEP 2.0.
What step have I left out? Help!!
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones
Owner: Dragon Rock Productions LLC
Dell XPS 435T/9000 Win-10 Pro 24gig RAM
IntelCore i7 CPU 920@2.67GHz
Pro Tools 2018.12
Focusrite Scarlett 8i6
Old 03-01-2014, 06:49 PM
DonaldM's Avatar
Default Re: Routing Audio Out of Transfuser Issue
Anyone?
Pro Tools 2018.12
Old 03-01-2014, 07:11 PM
Southsidemusic's Avatar
Repro'd it here aswell on our Macbook Pro in the midi room and same routing errors happens to that system too
We tried on the Mac Pro in the main room aswell but my apprentices seem to have that working, they are gonna do some more tests so I will come back later tonight US time. It's 04:10 here in sweden so I will hit the sack within an hour or two at the latest but if we get anything from them I will post back again. The 2 guys are in the studio (which is located on my property) in front of my house which was an old Café pictured in the "we are here" link on my SIG that we rebuilt into a 3 room studio a.k.a "The Hobbit Lair named by another member here on the DUC LOL
So we are on it aswell.
Best Regards
Christopher
PS. I will PM you next week with a few links to some of the songs we are working on and some we done like you asked for a few months ago
Best Regards
Christopher
South Side Music Group
WEBHOME
Old 03-01-2014, 08:37 PM
DonaldM's Avatar
Hey, thanks Christopher! At least it's not just me. I'm on a Win-7 system. So it appears to be a bug in Transfuser itself. Look forward to hearing your tracks!
And thanks for helping out with this. All the midi routing works fine as far as I can tell. It's just the audio out assignment that doesn't.
Pro Tools 2018.12
Old 03-03-2014, 04:51 PM
DonaldM's Avatar
Just a quick update on this issue. I updated from 11.1 to 11.1.2 today. However, that didn't fix the issue either. So, whatever the problem is, is must reside with Transfuser itself. Has anyone else experienced the same issue besides me and Christopher?
Pro Tools 2018.12
Old 03-04-2014, 08:05 AM
drogan88 drogan88 is offline
The 2.0 update now requires you to select the multiple output option in its setup window (at the bottom - you need flick the switch to the right) other wise it will push all audio to the main out. This was not the case in older versions and I nearly threw my computer out the window trying to fugure out what was going on until I read it in the manual.
Old 03-04-2014, 12:02 PM
DonaldM's Avatar
Where in the manual was that? I read through the section on setting up audio out, but don't recall seeing that. I'm not in my studio right now and won't be til Friday. I assume you mean the Transfuser set up area that likes like the inside of a synth?
Pro Tools 2018.12
Old 03-04-2014, 01:05 PM
DonaldM's Avatar
Okay, I looked at the manual online and, yes, there is mention of this in the section on setting up Transfuser. I think I missed it because I may have mistakenly been looking at the older manual and not the new one without realizing it (no wonder I couldn't find stuff!). And apparently the new manual only shows the new stuff, so you still need the other manual for all the features from before the update that are the same in 2.0. Here's what it says about the auxiliary outputs: :
When switched On, all of Transfuser’s auxiliary outputs are re-routed to the stereo master output. This may be helpful when troubleshooting complex output routing scenarios, where many aux outputs are being sent to the host application.
In other words, "On" means the Aux outs are Off. Just the opposite of what you'd think it would mean. Who knew?!?!
One other little beef I have is that when you save a preset and name it, and later edit the preset, perhaps adding another module, or whatever, there doesn't seem to be a way to simply click on the old preset and resave with the new data. That will get things confused in a hurry! The page about saving presets doesn't really explain much about any of that either.
Pro Tools 2018.12
Old 03-07-2014, 08:33 AM
DonaldM's Avatar
Default Re: Routing Audio Out of Transfuser Issue SOLVED!!!!!
Okay, I think I've got this puppy licked thanks to drogan88. If you have Transfuser 2.0 (not the earlier versions), you need to open the Transfuser configuration screen by clicking on the little tool icon on the lower right of the Transfuser window. On that screen, which looks like the inside of a synth...sort of... Make sure the "Optional Aux Outs" switched is ON. The manual is a bit confusing as it says:
That sounds like it means that ON routes the sounds ONLY to the Main output. But that is NOT the case. ON means the Main Output OR a selected Aux output can be made active. OFF means ONLY the Main output is used. To get sound from a module to an aux or audio track in PT, you must make sure the INPUT on the aux or audio track is the same as the OUTPUT of the Transfuser module's output you've selected.
This switch was not present on the earlier versions of Transfuser. For some reason, the default position is OFF, so if you're having the same issue as me [Christopher..ahem!], check this first.
Christopher: I'll bet if you check the system where you said it did have the aux available, I'll bet you'll find the switch is ON, and its OFF on the others.
Donald M
Pro Tools 2018.12
Transfuser GUI Issue RokVox Virtual Instruments 5 01-23-2012 09:54 PM
Transfuser issue Anarchy87 Virtual Instruments 7 03-16-2009 03:36 PM
Midi routing in transfuser - Different channels per track johnbhoy Virtual Instruments 0 02-17-2009 01:50 PM
Transfuser Midi CC Issue studiom Virtual Instruments 3 12-27-2008 08:41 AM
Major issue with Transfuser Compression Records Virtual Instruments 3 10-22-2008 02:42 PM
