Go Back   Avid Pro Audio Community > Announcements > Technical Alerts
Old 04-24-2008, 12:41 AM
Avid's Avatar
Avid Avid is offline
Administrator
Default Pro Tools 7.4cs4 Updates for all 7.4 Systems
Pro Tools 7.4cs4 updates for all Pro Tools 7.4 systems are available for download from the Pro Tools CS Updates page:
www.digidesign.com/support/csupdates
And related support sections for Pro Tools 7.4 software and hardware.
Previous installation of Pro Tools 7.4 required to use these updates:In addition to previous items from Pro Tools 7.4cs1, cs2, and cs3, the following fixes are included in Pro Tools 7.4cs4:
Pro Tools HD 7.4cs4
Mac & Windows
Fixed: DigiBase Aborts Cataloging if Audio File Comments Exceed 256 Characters (Item #100604)
- When attempting to catalog, a Neo Assertion error appears in the Project Browser
- The following error is generated when selecting a 256 + comment in the Workspace: "The value contained too many characters; previous value substituted".
Fixed: WAV Files Containing Non-English Characters Are Not Visible In Pro Tools 7.4, and Can Be Corrupted if Edited (Item #100502)
- Although the file comments are invisible in the DigiBase comments field, clicking in that field will delete all of the comments
- This only affects non-BWF WAV files
- This CS version restores the visibility of WAV file comments, as long as the field wasn't clicked in using earlier versions of Pro Tools 7.4
Fixed: Only the First 16 MIDI Inputs Are Available In The MIDI Input Enable Window (Item #76712)
- Window cannot be resized, scroll bar doesn't access other MIDI inputs
Mac Only:
Fixed: A QuickTime Movie Played Using Mojo or Mojo SDI Could Jump Out of Sync (Item #100497)
- This would only occur if playback crossed 35min-45 seconds from the session start
Pro Tools LE 7.4cs4
Mac & Windows
Fixed: The following error is generated when selecting a 256 + comment in the Workspace: "The value contained too many characters; previous value substituted". (Item# 100604)
Mac Only:
Fixed: MIDI Playback Timing Could Become Erratic as H/W Buffer Size Increased (Item #100756)
- This problem started in Pro Tools LE 7.4 for Mac OS X
Pro Tools M-Powered 7.4cs4
Mac & Windows
Mac Only:
Fixed: The ProFire 2626 is not displaying I/O properly in the I/O Setup window. (Item #101255)
- Note: If the I/O Setup does not show all Analog, Optical, and S/PDIF input labels after updating to 7.4cs4, launch the ProFire 2626 Setup Application via Hardware Setup to refresh the I/O Setup.
Administrator
HTML code is On
Pro Tools 7.3.1cs3 Updates for All 7.3.x Systems Avid Technical Alerts 0 06-01-2007 03:09 PM
Pro Tools 6.4cs4 Updates Avid Pro Tools TDM Systems (Mac) 4 07-17-2004 09:25 PM
Pro Tools 6.4cs4 Updates Avid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 07-08-2004 03:44 PM
Pro Tools 6.4cs4 Updates Avid Pro Tools TDM Systems (Win) 1 06-29-2004 03:45 PM
Pro Tools 6.4cs4 Updates Avid General 0 06-22-2004 10:11 PM
