error: not an audio record volume
If anyone can help it would be greatly appreciated. Here is what I'm using.
G4 laptop 17" tiger PT 6.9 M-Box When I try to save a new file it says: no audio record volume I changed the parameters within the save window but got the same message. Someone told me I had to go back to 10.3.... Is this true? If so, why? I did get the 6.9 update as well as the latest tiger. Still nothing. Can anyone help? Thanks in advance for your efforts. |
Re: error: not an audio record volume
You might try checking the status of the volume in the Workspace Window. Next to each volume you will find two columns; one labeled "A" (audio), the other labeled "V" You can set each volume to "Record", "Playback" or "Transfer". Make sure that the voume you want to use is set to "Record" in the "A" column. Actually it's just the letter "R".
I hope this helps |
You need to update to Pro Tools 6.9.2 or higher for compatibility with Tiger.
"Session must be on an audio record volume" ERROR. | tytanik | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-17-2006 02:43 PM |
must be saved on audio record volume - error | habernacks | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 09-29-2006 12:17 PM |
Session must be on audio record volume error | jonahgn | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-16-2006 03:49 PM |
Audio Record Volume ERROR...please help! | jacktracks | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-01-2006 10:59 AM |
I'm Getting A "Audio Record Volume" Error Message | MITCHELLBOY | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-15-2005 06:20 AM |
