Headphones sound like crap with 11R
I usually always play through headphones and they usually sound beautiful. The Headphone output on the 11R sounds like a can of bees (tinny and no dynamics) - would getting a small poweramp help? I can run it into one of my amps but the only amp with a headphone output is Fender Mustang I just got. If I pick up a small Poweramp would that help?
Re: Headphones sound like crap with 11R
Poweramp? If you have demanding headphones you want a quality headphone amp. Start with telling us exactly what headpones you have. You might also have damaged headphones, or less likely a damaged/faulty amp. Are you only listening to the Eleven Rack with headphones? Or what does it sound like out the monitor outs? If you've only just listened to in with headphones I'd generally start by suspecting pilot error than the headphones. Darryl |
What headphones are you using? Do you have any more to try? The 11R sounds great with phones for me and Im not even using super expensive phones.
what kind of presets are you using with phones? If you setup a preset while playing through an amp or floor monitor or even studio monitors in a room that is not tuned, the rig probably won't sound the same through phones. Try starting a rig using headphones and build it so it sounds good through them.
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
I'm using an el cheapo pair of Koss (probably $20)... I use them for other sims & they sound pretty good - I'm going to find a better set on sale. Some presets sound fine (Jangly Stereo for instance) but lot of the high-gain ones sound like [bleep][bleep][bleep][bleep].
any recommendations? $100 or less... |
I also like Sony headphones, but I would not suggest them, they seem to really hype the high end. Beyerdynamic makes some really great phones as well, something like the DT 770 should work great. The 11R probably won't be able to drive them hard since they are 250ohm, but you should be able to get loud enough. Be sure to spend at least $100 (msrp) buying phones priced at $35 will sound like $35 phones. You will want CLOSED headphones.
Have checked that your speaker cabs are engaged. If they are bypassed - it will sound like bees in a can...
OP - Check your "Amp Output" settings. If either is set to "Rig Out No Cab", it will defeat cab and mic sims on ALL outputs, including the headphones.
Good point. If you have been playing through a physical amp/cab you may have forgotten that you turned off cab modeling.
I have a set of Sony MDR-7506 (paid $150), clean sound and pretty neutral. I think rigs I'll setup with them will translate well everywhere. But they are a bit dull to listen to (no hype) and not very sensible.
When I want to have fun I use my Shure e02 IEM (paid $90). They are a tight fit but once fitted properly it seals the ear and it's like playing without headphones, light, very confortable with a lot of bass (perfect when I play bass guitar!!!). |
I have very good results with a Sony MDR-7509 HD
No Sound Through Headphones | houser8732 | Windows | 12 | 11-02-2013 01:20 PM |
no sound from headphones? | Darkk927 | Pro Tools M-Powered (Win) | 2 | 04-23-2008 08:07 AM |
no sound from headphones | simon123456789 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-19-2008 05:18 PM |
Why does Control24 sound like crap? | TuT | ICON & C|24 | 8 | 09-04-2003 11:29 PM |
