Old 07-28-2023, 05:32 PM
Mikey MTC Mikey MTC is offline
Default Dash and space before every scribble strip name
I don't know what I did, but for days now, every track name scribble strip on the D-Control has a dash then a space before the name. So obviously this leaves only 4 characters for the name instead of 6.
Can someone tell me how to get out of this mode, or whatever has happened?
As seen in this horrible, dirty looking photo -
https://www.dropbox.com/scl/fi/al395...w00bhlbc2&dl=0
Old 08-02-2023, 05:52 PM
Led Led is offline
Default Re: Dash and space before every scribble strip name
Sounds like you are in group/track display mode for the channels..on my D-Coomand there is a buttom under the "Do to sel" button in the centre section called "Display mode" that cycles through the various modes. Pushing that should get you back to normal eventually, I think there are 5 modes maybe..
Old 08-02-2023, 06:16 PM
PERFECT - that was it. thanks so much.
On the D-Control, that button is hiding between Mute Clear and Auto Suspend and clearly I had a hand slip and unwittingly pressed it .... for the first time ever.
Thanks again.
Dash before channel name on scribble strip.. D'Animation ICON & C|24 2 02-16-2012 01:01 PM
Scribble Strip Display tim carter ICON & C|24 2 01-24-2010 05:25 PM
scribble strip going dim off and on WilliamDC ICON & C|24 2 08-29-2006 08:31 AM
scribble strip syntheticrhyme ICON & C|24 1 05-15-2002 07:22 AM
Scribble Strip Disapearing MeltMediaMusic ProControl, Control|24, Command|8 0 05-22-2001 04:27 PM
