Old 01-06-2018, 02:03 PM
Terry Wetzel Terry Wetzel is offline
Default Pro Tools 12, what's the solution?
Hi Guys. I've been trying to find my way around PT's 12 for a while now and as
far as being able to make it do what I want,(for lack of a better way to put it),
I am continuously frustrated! If I select a clip to do any kind of editing it only plays back once and moves on! Then I have to go back, select the clip again and start over! I hope someone understands what I'm saying. It's probably not the best way of expressing the problem. Where can I find help and advice
aside from the reference manual. There seems to be nothing on this subject in the You tube videos. What I would really like is some instructional material
on how to work the basics in Pro Tools 12. Any help and/or advice will be appreciated. Thanks
Old 01-06-2018, 02:34 PM
Tweakhead Tweakhead is offline
Default Re: Pro Tools 12, what's the solution?
Hey Terry . . . press the "N" key once.
Does that solve it ?
Old 01-06-2018, 02:36 PM
Maybe you want Loop Play?(right-click on the Play button at the top of the EDIT window to see the options, just as you also can do to the Record button for those options)
Old 01-06-2018, 04:04 PM
The Weed's Avatar
The Weed The Weed is offline
"N" key works in Command Focus Mode or go into Preferences and UNcheck Timeline Insertion/Play Start Marker follows playback. Look in Chapter 8: Preferences under Operation.
Checked, the cursor stops where you stop, so if you have a clip highlighted it won't be when you stop playback. Unchecked, the cursor goes back to where it was when you started playback, so if you have a clip highlighted, it remains highlighted.
In Commands Focus Mode, "N" toggles the Preference On/Off (UNchecks/Checks it) and it's very easy to inadvertently hit the "N" key.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 01-06-2018, 04:09 PM
john1192 john1192 is offline
Look at youtube videos for - Dynamic Transport, Uncheck Link Edit and Timeline Selection, Loopback .. all these tools will you get what you need ..
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 01-07-2018, 01:53 PM
Thanks everyone for your help. Obviously a lot of things must have happened between Pro Tools 12.6 and 12! I'll try to work it out with each of your suggestions.
Old 01-07-2018, 01:59 PM
dig in a little .. none of these things are that new .. shout out if we can help more spefically ..
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 01-07-2018, 03:51 PM
The Weed's Avatar
"N" toggles the Preference On/Off and the setting in Preferences have both been around long before PT12.
SonoBus
Old 01-07-2018, 08:16 PM
Severe Severe is offline
I’m fairly sure the solution to most of your Pro Tools 12 inquiries can be found here: http://resources.avid.com/SupportFil...ide_12.8.2.pdf
Old 01-09-2018, 06:02 PM
hengus hengus is offline
I found this to be a good resource. He also talks about the issue that you are having I think.
https://youtu.be/QwVgaBOvP9s
Sent from my Nexus 5X using Tapatalk
Pro Tools 10 iLok solution ReynaldoPena Windows 1 11-09-2012 08:38 PM
Best Video Solution for Pro Tools M-ManLA Pro Tools TDM Systems (Mac) 9 06-09-2009 11:43 PM
Pro Tools LE 7 Solution Tom Glander 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-12-2005 04:37 AM
Pro Tools Midi Solution audiofx Pro Tools TDM Systems (Mac) 2 08-19-2003 04:17 PM
pro tools/ Sonic Solution greenz General Discussion 1 07-27-1999 04:35 PM
