Old 12-04-2017, 06:52 AM
Terry Wetzel Terry Wetzel is offline
Default Mixer/Pro tools.
For the first time ever I have been able to successfully hook up my Mackie 24/8 mixer together with Pro tools 12! In doing so it occurred to me that this combination will require calibration of both the mixer and Pro tools. I know that PT's should be calibrated to -18 dB = 0. I assume the mixer, using a sine signal of 1khz = 0dBFS is correct but I'm not sure. Is this a correct assumption?
Thanks.
Old 12-04-2017, 07:12 AM
Wizzoboy's Avatar
Wizzoboy Wizzoboy is offline
Default Re: Mixer/Pro tools.
No. The output of the Mackie if set to 0vu with 1khz tone should read -18 on the input of PT. -18 on PT equals 0vu giving 18db of headroom before 0dbfs. A 1khz tone at -18 out of PT should read 0vu on the Mackie.
Dell Precision 490 Workstation, dual 4 core 5355 Xeon, 16gb Samsung DDR2 ECC Ram - Windows 7 Ultimate - Nvidia GTX 650 - 3 x Internal WD Blacks - PT 2018.3 - Digi 002R - Original Mackie HUI - 3 screens - JBL Monitoring.
Dell XPS 8700 i7-4790 - 24gb RAM - Windows 10 - Nvidia GTX 1060 6GB with Studio driver 546.01 - 2 x Internal Samsung 860 EVO SSDs, and MSATA card - Davinci Resolve Studio 18.6.4 - 3 screens - Blackmagic Speed Editor - MK1 Presonus Faderport - Canon C100 mk2 - Atomos Ninja 2 - Zoom H2n
Old 12-04-2017, 11:30 AM
john1192 john1192 is offline
does this not depend on your Audio INterface ??? for example, mine is -16 !!!
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 12-04-2017, 01:51 PM
Both of the above replies are correct. And yes, it does depend on your interface. If you can post the exact models of your PT interface, and your Mackie mixer, then we can take a look. Is there a particular reason you want to use the Mackie with Pro Tools? Are you using it for tracking? Mixing?
A little background...
This is a topic that is pretty technical and can get a little complicated at first.
-18=0 is an incomplete statement. A more complete statement would be -18dBFS = 0VU = +4dBu.
dBFS is a digital signal level that only exists only in the digital domain and doesn't have an absolute correlation to any analog voltage. dBu is an analog voltage level referenced to 0.775 volts RMS (AC). So 0dBu = 0.775 Vrms, and +4dBu = 1.228Vrms.
The D/A converters are calibrated to match a specific digital level (anywhere from -14dBFS to -20dBFS) to a specific analog level (usually +4dBu, or 1.228Vrms, for line level balanced outputs). 0VU is a further calibration to match a specific analog level (+4dBu) to a reading on a VU meter (0VU).
Scott Gatteño
Old 12-04-2017, 02:24 PM
Drew Mazurek's Avatar
I'm going to ask the obvious question.... why?
What do you hope to achieve doing this? If you think you'll be imparting any sort of analog "mojo" with the Mackie, I think you'll be disappointed.
If you need a clean mixer to blend mics together on their way to the DAW (a dubious endeavor these days) because your interface only has so many inputs, I suppose this would work, but I'd simply recommend you get another interface and not mess around with this.
www.drewmazurek.com
Old 09-17-2018, 08:46 PM
coleeddy coleeddy is offline
Thanks.
Can you tell me how you got your mixer hooked up with pro tools?! Thanks
Old 09-18-2018, 08:55 AM
EGS's Avatar
EGS EGS is offline
+1
Click for audio/video demo
Click for resume
Pro Tools non-HD. Mixer dpm ? Jassbag Pro Tools 10 2 11-04-2011 01:08 PM
Pro Tools 9 with my mixer? musicislife8181 macOS 1 08-23-2011 09:32 AM
New pro tools le 8 program trying to hook up a mixer need help (old mixer) Dre_Note$ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 06-28-2010 04:57 PM
003 mixer with LE pro tools wizecrkr ICON & C|24 1 04-22-2008 03:42 AM
pro tools and mixer billboard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-16-2007 07:21 AM
