Old 09-24-2015, 08:02 PM
theivories theivories is offline
Default Import track or session files ? And Import, then SAVE ?
When do I import track files, as opposed to session files in ProTools 11.
In relationship to that question....do I have to "import" files first, in order to "SAVE" those files to my drive on my MacBook ? ( I'm deliberately importing from an external hard drive of these songs....I want them imported onto the MacBook. Not going to change the arrangements at all.) Thanks.
Old 09-25-2015, 07:36 PM
Post Re: Import track or session files ? And IMport, then SAVE ?
There is no such thing as track files within Pro Tools.
In relationship to that question....do I have to "import" files first, in order to "SAVE" those files to my drive on my MacBook ?( I'm deliberately importing from an external hard drive of these songs....I want them imported onto the MacBook. Not going to change the arrangements at all.) Thanks.
If your goal is to copy the audio files on your external drive to the drive inside of your MacBook, then you want to use the Import Audio command (File-->Import-->Audio). Select the audio on your external drive and press the Copy button. You have to do the import before you save your session. You should then quit Pro Tools, disconnect your external drive, relaunch Pro Tools, and reopen the session you imported into. If you do not see an error message about Pro Tools being unable to locate missing audio files, then you are set.
Note that unless you have a license for Pro Tools | HD that you are best served by having your audio files on a dedicated drive (not partition). HD users can get around this limitation by enabling the Disk Cache (Setup-->Playback Engine).
Import Audio Files to Same Track antiwebbite 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 05-29-2020 06:58 AM
Import Files To One Track GTBannah Pro Tools 9 6 03-12-2012 09:32 AM
Import track color in import session data deardaddy Pro Tools TDM Systems (Mac) 5 06-11-2007 06:35 PM
How to import 44.1 files into a 48k session b mcgibney 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-25-2007 01:11 AM
How to import a 6.1LE track in a 5.3 TDM session? steals Pro Tools TDM Systems (Win) 3 10-18-2003 12:18 AM
