PT 9 I/O setup import/export/ bug? feature??
Not sure if anybody else is having the same issues that I am having with the I/O setup in PT9, but it seems to be acting very differently than I remember from PT8. We switch I/O setups regularly as we do a lot of post and a lot of music, and I like to keep everything labelled well for each to make routing and bussing easy within the different sessions.
I finally had time to setup some new I/O setups in our studio yesterday after upgrading a couple weeks ago. When importing the i/o setup into a blank session, or a previous session, it appears to only import the settings for the page that you are on i.e. input, output, bussing etc. I do not remember PT8 behaving this way. (PT 8.1 may have, but I didn't have time to check it out as I was only on it for a few weeks and made due) So, to "import" the whole setup, you have to change which "page" your on and import the i/o setup again and again. Very frustrating! This is completely repeatable. After a few frustrating sessions, and trying to figure out what was going on, I've had some time to play with it, and this is what I have found. Also, I haven't been able to figure out the sequence, but after changing i/o setups somehow, when creating a new session from a saved i/o setup, some of the outputs will be listed as "n/a" in the i/o setup in the new blank session! After this has happened, I have to reassign (the exact same labelled outputs to the buses) and "re-export" the settings so that next time it works properly. Is it just me?? but this seems awefully wrong and confusing not to mention time consuming! Digi, if this is a new "feature" on how to import i/o setups, is there any way to change it back??!! Thanks, Chris James |
Re: PT 9 I/O setup import/export/ bug? feature??
Has no one else encountered this problem?? I find that hard to believe. Digi tech support, can you confirm this as a bug or a "new feature" please.
Thanks.... |
The manual has all of this around pages 94ish and 112ish. Make sure you are reading the PT9 manual as these are all new "features". They are fairly confusing until you get used to them,..ff |
Thanks FormFunction! Seems really weird to me why they would do this as if you only import part of it, it messes up your whole bussing etc. and you have to remap everything; but, I guess someone must have asked for that "feature" and Digi through it in without telling anyone. Very frustrating and time consuming! I wish there was more documentation on "major changes" that Digi would send along with each new release so that we could skim through it for important changes as I don't need to ( or want to) read the whole manual again every time!
And here is a good tutorial on the new I/O setup http://akmedia.digidesign.com/suppor..._v81_67827.pdf enjoy.. ff |
The PT 9 IO is the most Non-user friendly change Avid has ever hit us with. Obviously the person that designed that portion of the upgrade has NEVER worked in a recording facility or post house. Every session I move from one room to another is giant arse ache!
I hope they hear our cries to go back to an IO template that is user friendly! Ps. I designed and built and installed Odds On recording in Las Vegas, as well as the original install on The Killers' studio "Battleborn" plus numerous setups of HD rigs in Las Vegas.... So I know how things should work! In fact ask Ron St. Germain! He recently did what I am being forced to do... SWITCH TO LOGIC! |
I feel your pain and am still finding ways of working with the new system, haven't given up yet.
As for switching to Logic? Yeah, good luck with that. (see FCPX) |
yeah. it's a huge terrible mess. check out this thread. no updates seem to fix it. it's the worst.
http://duc.avid.com/showthread.php?t...ight=ryandcole |
No "Session Overwrites current I/O setup when opened" is not checked. If you don't know exactly how that checkbox works you may well be creating your own problems. Once again, it comes down to RTFM...
X Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...) Just rockin'...what more is there? Bill in Pittsburgh |
Export Selected Regions - Feature Removed? | beardedaxe | Pro Tools 11 | 7 | 02-26-2014 03:22 PM |
Export Tracks to Session, Feature Request... | JR Fountain | Post - Surround - Video | 9 | 09-07-2011 04:23 AM |
FEATURE REQUEST: Export Session Data | freeBase | Pro Tools TDM Systems (Mac) | 5 | 05-22-2009 09:23 AM |
Feature request - Consolidate on Export | Sonsey | Post - Surround - Video | 2 | 10-20-2007 04:28 PM |
Feature Request: Export Selection to New Session | chroma17 | Pro Tools TDM Systems (Mac) | 3 | 03-14-2007 04:40 PM |
