HDD compatibility
This is my drive... |
Re: HDD compatibility
My first thought would be major slow as I had to upgrade mine to 7200 rpm for the system drive. I take it you are using the USB mbox?
James Shelby SRS Labs Aurora, Colorado |
Hi ninboy, welcome to the board!
a quality external USB HD ist still better than the internal HD. there are actually some good USB chipsets out there, though I never went there. And some PT users actually use USB HDs for recording. Some external cases with a OXFORD 924 also feature USB2 ports. If you still plan to use the internal HD make sure you NEVER fill it up to more that 50%. the File System works best that way. best
last: PT11.3.1 |
if your macbook has a card slot, you can SIIG FW card.
i7-860 / 12GB Kingston / Intel DP55WB / 500GB Barracuda / 1TB Deskstar W7x64 Focusrite Saffire Pro 40 / Pro Tools 9.0.3 Mics, Guitars, Amps, Basses, Drums, Keys http://overtheeffect.bandcamp.com |
That 5400RPM drive has to go you need a 7200RPM drive. That speeds up the OS, virtual memory, and all app's. Especially need the faster internal if you aren't going to use an external drive.
Steve B. ---------------------------------------------------------------- If you think you can or if you think you can't, you're right. |
I'm just going to keep all my stuff on the external, and use the system hdd for what I'm working on.
I'll also set up my macs time machine, so If I do damage my internal I still have a year of warranty and I will get an upgrade than. |
i haven't had a problem with pro tools so far.
I'm not trying to state the obvious but this is one of the major mis-steps from Apple to not include the Firewire port (and also have no way to add one on the short lived unibody MacBooks. If you look at the WWDC keynote, Apple clearly admits to this shortcoming and with the new 13" MacBook Pro have added a Firewire800 port specifically for people like us doing audio. There is unfortunately no good solution for Protools and the unibody MacBook that you have. At best you can upgrade the internal drive to 7200 or limp along with a USB drive. Both of these are known to have problems. If I were you, and Protools is an important of my needs, I would sell the MacBook and get a Macbook Pro. Sorry to be the bearer of bad news, but you already knew that.
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
Yeah I know, I'm just going to deal with it for a while, I'm only a student and I'm not doing huge productions or anything like that, i will up grade later.
I did however get the USb to work, just partitioned the drive into Mac OS journal. And I can record and playback via the external hdd. |
And I only have the mbox2 factory, with 48kHz sampling rate, so nothing serious.
PT 8 HD/PT9 Compatibility, 10.6.5 compatibility, OMF Logic9/PT9, iLok upgrade | benosullivan | Pro Tools 9 | 2 | 11-17-2010 11:05 AM |
V9 Compatibility | GTBannah | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 11-16-2010 04:51 PM |
Mac OSX Compatibility | Keniko | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-24-2007 09:33 AM |
UAD-1 and PT7 Compatibility | M15 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-08-2005 11:19 PM |
PCI-X Compatibility | kcurry | Pro Tools TDM Systems (Mac) | 6 | 07-14-2003 05:45 AM |
