Pt 8 (hd) omf import pops on avid created fades
Dear Digi
I don't know what has changed between PT 5-7.x to PT 8 HD, but now - importing the Avid generated OMF's I am getting pops on their tracks. NATURALLY THIS NEVER HAPPENED BEFORE It seems that the pops are coming from the avid created fades which PT has always recreated pretty flawlessly. If you'd like one of these omfs lemme know. It's pretty consistent thus far. P.S. REQUESTS REMEMBER when the user use to have a choice on where to put the OMF imported material? I'd LOVE that option to re-occur so that I can keep my OMF audio in a separate folder.... AND OMF EXPORT - when you select AVID and EMBEDDED you really should NOT have to select 16 bit, it should be the default as the avid ONLY reads 16 bit. anyway - running on the intel mac pro. hd 8 cs 2. not quite the latest os, but digi approved osx. prefs are 'clean' databases trashed, all the usual suspects checked. It would be AWESOME to have a conversation with the department that handles OMF / file translation and not a Digi Tech who hasn't ever used OMF import. PLEASE DON'T TAKE THAT PERSONAL. Many Thanks scott
[img]/images/graemlins/tongue.gif[/img] <<<<< in the psychiatric emergency handbook this is bad news. |
Re: Pt 8 (hd) omf import pops on avid created fades
I prefer and mostly use referenced OMF/AAF but embedded should work wth 24bit as well. frank.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
I had NO idea about the 24 bit. I don't know where you are working, but most Hollywood film setups... well i shouldn't say most. MANY are still running OS 9! Thank you though. FRANK - one last question. Have you EVER been successful in SENDING an OMF that doesn't contain the 'sample' accurate edits? Even if I test this by highlighting an edited OMF region FROM THE AVID in my PT Session (in other words on their frame lines) and create a bounced region..... When I export that region as an OMF, I still get - THEY STILL GET the sample accurate edits. Some Avid asistants are driven nuts by them. (They are no big deal) I can never seem to get rid of them. Just curious. Thanks again.
[img]/images/graemlins/tongue.gif[/img] <<<<< in the psychiatric emergency handbook this is bad news. Last edited by smlworld; 06-04-2009 at 08:03 AM. Reason: cause i'm an editor |
Not sure if I understand what you´re saying about "sample accurate edits". There is no way NOT to select "quantize to frame boundaries" and OMF/AAF back into the AVID because the AVID does not support sample-accurate editing. You have to select this otherwise your OMF won´t open in the AVID. PT will then add some empty audio up to the next full frame boundary. Your content will still be sample-accurate but the actual clip will start on full frames. frank.
New fades showing up blue (not being created)? | kirkbross | macOS | 2 | 07-16-2013 07:15 PM |
fades rendering incorrectly - wrong fade created | levelaudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 08-06-2008 11:41 PM |
fades not being created on allocated drives | jimlongo | Pro Tools TDM Systems (Mac) | 0 | 12-02-2005 11:24 AM |
Unwanted Fades created after recording | ewan | Pro Tools TDM Systems (Mac) | 1 | 11-08-2003 07:46 PM |
OMF Import from Avid POPS - ouch! Clock Settings?? | smlworld | Pro Tools TDM Systems (Mac) | 7 | 09-09-2003 07:09 AM |
